Abs lights on with 4 codes.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brandon0928, Nov 11, 2022.
  1. Brandon0928
    Brandon0928 Light Load Member
    184
    105
    May 14, 2022
    2018 Peterbilt x15 cummins
    Where should I start ?
    What to check first ?
    (SPN)175
    Description:
    Low priority warning light on
    Severity:
    Not available
    Current Status:
    Active
    Times Logged:
    14
    Source:
    Telematics Device
    Protocol:
    Telematics Device
    Advanced Details:
    Selection:
    (SPN)802
    Description:
    Relay diagonal 1
    Severity:
    Not available
    Current Status:
    None
    Times Logged:
    6
    Source:
    Vehicle
    Protocol:
    J1939
    Advanced Details:
    Voltage below normal or shorted to low source (FMI: 4), SA: 11
    Selection:
    (SPN)791
    Description:
    Wheel sensor ABS axle 2 left
    Severity:
    Not available
    Current Status:
    None
    Times Logged:
    32
    Source:
    Vehicle
    Protocol:
    J1939
    Advanced Details:
    Data erratic intermittent or incorrect (FMI: 2), SA: 11
    Selection:
    (SPN)794
    Description:
    Wheel sensor ABS axle 3 right
    Severity:
    Not available
    Current Status:
    None
    Times Logged:
    18
    Source:
    Vehicle
    Protocol:
    J1939
    Advanced Details:
    Data valid but below normal operational range - most severe level (FMI: 1), SA: 11
    Selection:
  3. Rideandrepair
    17,321
    56,197
    Aug 8, 2015
    I’d try pushing the two sensors mentioned in making sure they’re contacting the tone rings. They probably are, but sometimes can slip out. Sometimes it’s caused by a loose wheel end. That’s free doesn’t cost anything. Chances are a wire is damaged. Visually check each sensor for a damaged wire. Hopefully they have a short wire from the sensor, and a longer extension wire going to the ecu. Usually the wires got a break in it. Often it can’t be seen. You can buy an extension wire long enough to reach from the ecu to every sensor. Try replacing the wire. Must pull the Trailer about 5 mph to clear an active code Any remaining codes will still be active, so the light won’t go off till every codes fixed. You probably need a new wire for each sensor mentioned. You can buy 2 wires and only open one. Try it on one, and if it doesn’t fix it, try it on the other. Worst case scenario is you’ll have an extra extension wire for future diagnostic’s if you ever need one. They’re about $30. If your sensors have one long wire, instead of a short wire and extension wire. You’ll need to pull the wheels and drum off to replace the whole sensor. If that’s the case, I’d replace it with a short wire sensor and an extension, since the sensor itself is just a magnet, never goes bad, it’s always a wire.
    gentleroger, Brandon0928 and JoeyJunk Thank this.
  4. Brandon0928
    184
    105
    May 14, 2022
    Thanks for the info!
    Rideandrepair Thanks this.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    And if you are on dirt lots a bit, simple piece of mud between the tone ring and sensor can do it too.
  6. Brandon0928
    184
    105
    May 14, 2022
    I haul cattle so I’m actually on gravel roads every day and all the places I got are dirt/rock lots
