ABS Module?
Discussion in 'Questions From New Drivers' started by jmcdaniel05, Apr 14, 2016.
  1. jmcdaniel05
    jmcdaniel05 Bobtail Member
    31
    6
    Jun 29, 2015
    I have a 2014 International Prostar. Its a company truck, not mine. About 3 or 4 months ago the ABS module went out, had to sit for a day and a half then they told me it would be two weeks to get the part. So they sent me from TN to OH to get another truck (none in TN). I was driving it back to TN with a load and the driveshaft dropped out from under it. Had to sit all weekend in a motel. Ended up being brought back to TN and luckily truck was ready it had been probably a little over a week by that point. Anyway the ABS module is going out again or is out. Its not causing any problems. Just got the ABS, traction control light and some little triangle light on plus it says ABS module in the message center. This is the same thing it did before. Im just wondering if its something I can just ignore or do I definitely need to get it fixed? Last time after they found it was "fried" they wouldnt let me drive it.
  3. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    usually it is just that the ABS function is not working, but you still have your brakes. you would want to make sure you do not jam on the brakes in any sort of panic stop. other than that, do as they say for you to do.
    if you were to say, be in an accident, the recorder will know you had no ABS, this can be a detriment to you later on.
  4. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I think from a CMV cop's POV, their guidance regarding ABS issues dictates "vehicle should be serviced at the next convenient and practical opportunity but not put off too long". I had read this somewhere on the ABS manufacturer's web site, and I'm paraphrasing. I have been unable to find anything related to ABS issues in the FMCSA book but might be corrected by someone who has more time then I do.
    But the point is, an ABS light (trailer or tractor) should not be an issue that get's you put OOS or ticketed as long as they are made to understand it just recently occurred and it is "headed to the shop currently"
  5. bondoron
    bondoron Bobtail Member
    15
    9
    Mar 30, 2014
    The company I work for has about 15 Prostars. What you are saying is so common our drivers don't even report it anymore. We have 2 trucks that this happens to at least once a day. Shut it off start it back up and good to go usually. Otherwise it just gets cleared from the computer. ABS and TPM are both extremely common in our trucks anyway.
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Correct.
    A malfunctioning anti lock system is not an OOS condition. The system only has to be present and warning lamps functional.
    A malfunctioning tractor anti lock system will sometimes cause your traction control/stability control to go offline as they use the anti lock wheel sensors to detect wheel spin.
  7. Toomanybikes
    Toomanybikes Road Train Member
    2,443
    3,345
    Apr 8, 2009
    I read somewhere that when surveyed 1 in 6 trucks on the road had ABS problems. So, they are pretty common.
    I understand it is not a out-of-service condition for the Feds, but as alway state and local DOT many see things different and often do. It is however a ticket and points on your record.
  8. Moose1958
    Moose1958 Road Train Member
    15,270
    33,864
    Dec 17, 2010
    Williesburg, Virignia
    I drove several prostars at some point all of them had ABS issues. A lot of equipped trailers did too.
  9. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    I would ask them to show me where it is a citable offense.
  10. xsetra
    xsetra Road Train Member
    5,174
    7,111
    Aug 21, 2011
    393.55 in the little green book
