ABS not required
Discussion in 'Heavy Haul Trucking Forum' started by CharlieK, Nov 22, 2016.
  1. CharlieK
    CharlieK Medium Load Member
    374
    4,454
    May 13, 2015
    Minnesota
    Looking at specs for the XL120, 110, and 80 trailers, it says ABS not required. Are RGN's exempt from ABS? Why?
  3. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    Used to be anything above 50 ton wasn't required to have abs, not sure what the current rule is.
    snowman_w900 and CharlieK Thank this.
  4. Rontonio
    Rontonio Road Train Member
    6,251
    45,425
    Aug 9, 2009
  5. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    My 55 doesn't either but it's an 06 so I was allowing for a change since then. But yours is pretty new. Curious, was abs an option?
    snowman_w900 and 4mer trucker Thank this.
  6. Rontonio
    6,251
    45,425
    Aug 9, 2009
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    Abs is exempt on 51 ton or more.
  8. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,889
    May 1, 2013
    In purgatory
    The reason why is air reservoir capacity.
    The amount of air capacity required by an air brake equipped vehicle is determined by the number of brake chambers on the unit.
    The more tonnage carrying capacity you have, naturally requires more axles, which correlates to more brake chambers thus increasing the air reservoir capacity.
    ABS systems have the ability to make way more applications and releases than a driver can due to ECM control as opposed to an actual air pressure signal from the brake pedal.
    This means the ABS system has the ability to demand more air volume than the reservoir capacity as well as the ability of even a >30CFM twin cylinder compressor can replenish via a 3/8" DOT approved brake supply line can handle.
    So to remove the possibility of an ABS system to completely deplete the air system and engage the emergency spring brakes to a total unit lock-up leading to a loss of vehicle control, large tonnage (>50) units are exempt.
    So it's actually safer for large capacity unit to NOT have an ABS system.
    ChevyCam, LoneCowboy, Bo Hunt and 14 others Thank this.
  9. passingthru69
    Yep and you don't need maxi brakes either
  10. Rontonio
    6,251
    45,425
    Aug 9, 2009
    I don't have those on the big trailer either
    johndeere4020 Thanks this.
  11. johndeere4020
    8,522
    119,291
    Jan 1, 2010
    For some reason my 55 has them on the middle axle, this is the only lowboy I ever pulled that had Maxi brakes.
    passingthru69 and Dye Guardian Thank this.
