ABS power/ fuse location on 2005 Columbia
Discussion in 'Freightliner Forum' started by Freightlinerbob, Oct 12, 2013.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I have no power in the ABS constant power (Blue/ Center pin) circuit at the back of the cab. Pin was corroded off so I replaced the plug but still have no power.
    Next check is the ABS fuse. Anyone know where it is?
    Thanks
    FLB
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    ck under R top dash, push button (fuse)
  4. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    That's the first place I looked. If it's in there, it's not readily marked.
    Thanks.
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    breaker black plug in 3ed from L ft. but will CK. in book for you.
    Freightlinerbob Thanks this.
  6. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Where's Pablo when you need him? LOL.
  7. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I found another fuse box inside the access panel on the drivers side B pillar. There is an ABS fuse there but it was OK.
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    That is where the ABS unit is.... in the pillar door next to the driver's seat. One screw access.
  9. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Yes but my tractor ABS is fine. I'm missing power to the blue wire that goes to the trailer. The prong was corroded off, I replaced the plug but there isn't any power coming from the tractor. On this truck that power was constant even with the key off.
    I just realized I was looking for something marked ABS: trailer but that's probably not what I should be looking for. Trailer power maybe?
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Look for "TRAILER AUX" or "AUX PWR". Something along those lines, I've never seen one labeled as trailer ABS.
    azcardnlz Thanks this.
  11. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    It's labeled "Trailer Aux-30" top center of the main fuse panel. It's all fixed now.
    Thanks everybody.
