ABS/Trac control light illuminated
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 379Hoodlife, Mar 29, 2022.
  1. 379Hoodlife
    379Hoodlife Bobtail Member
    4
    Ok, need some advise here. Peterbilt 379 2007. My abs/trac control lights are illuminated. Went to PB and replaced ecm for this system. They performed chug test on all pressure modulator valves. Tested resistance on pmv wires, all were in spec. Performed voltage checked on pmv, all in spec. All good no more lights, park up for the night, next day when to start truck and abs/trac control lights on again. No chug test from pmv. Could the pmv be bad or shorting out? Any advice would be greatly appreciated.
  3. FLHT
    FLHT Road Train Member
    1,407
    2,480
    Aug 2, 2014
    Should be a reset button in the top of map pocket.
    Push in and ABS light should blink.
    But light will not go out until you get moving.
    May have to shun down motor and restart.
  4. 379Hoodlife
    4
    Where is the map pocket located?
  5. FLHT
    1,407
    2,480
    Aug 2, 2014
    In front of shifter little cubby its inside
    push button up
  6. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    When you are dealing with any electronic module like this, the first step is to always check for fault codes. Having a light on can mean literally anything. In order to help you better we need to know at least what code is getting logged.
    spsauerland Thanks this.
  7. 379Hoodlife
    4
    When it first happened and taken to a PB dealer it had a 12-7. Don't know what it is now, just assuming same fault as before since it reappeared.
  8. Heavyd
    7,804
    6,253
    Feb 4, 2009
    If you have a Bendix system, Bendix is very sensitive to shorts to ground. They have to check all the PMV leads to chassis ground. Everything has to be totally open to ground. Even resistances in the mega ohm range will cause this fault. The Bendix ECU is unable to pin point which modulator common is shorted, so the all have to be tested. This also includes the traction control valve if equipped.
  9. 379Hoodlife
    4
    They tested all pmv's, ground , resistance and power all checked good. They didn't test the tcv, where is that located? My 379 has this feature, in tried pushing the trac switch but nothing happened. Light stayed on.
  10. Heavyd
    7,804
    6,253
    Feb 4, 2009
    The traction control valve is built into your rear brake relay valve. Look for a relay valve with a wire harness coming from it.
    spsauerland and 379Hoodlife Thank this.
