AC blowing hot air, after system vacuumed & it worked for 3 days.
Discussion in 'Ask An Owner Operator' started by aceman18, Jul 1, 2023.
  1. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    Just did a A/C fix the other day the UV light could not detect because it was in the evaporator in the bunk unit
    Siinman and Rideandrepair Thank this.
  3. aceman18
    aceman18 Bobtail Member
    30
    30
    Jul 1, 2023
    It's hot air in general, I don't think thr outside. That's a good idea, ill try the controls and see of that's s problem also!
    Rideandrepair Thanks this.
  4. aceman18
    30
    30
    Jul 1, 2023
    Hmmmm that's interesting. Even if the bunk doesn't work at all? I have to fix the fan and/or resistor, so it doesn't even turn on.
  5. AModelCat
    160,448
    Is there any condensation running out the drain tube?
  6. Last Call
    7,568
    45,902
    Mar 15, 2021
    It's still part of the HVAC system even if the fan doesn't work
  7. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,032
    Dec 31, 2010
    Washington, PA
  8. aceman18
    30
    30
    Jul 1, 2023
    Yes there is.
  9. aceman18
    30
    30
    Jul 1, 2023
    Ok, ill look into that.
  10. AModelCat
    160,448
    A/C should be working then. I'd be leaning towards a blend door/water valve issue.
    D.Tibbitt, Rideandrepair and Magoo1968 Thank this.
  11. aceman18
    30
    30
    Jul 1, 2023
    Sounds good! I'll look into that driver! Do you happen to know if the classics have a blend door actuator?
