AC blows warms after running a bit
Discussion in 'Peterbilt Forum' started by kwforage, Jun 17, 2012.
  1. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    94' 379. I bought it with no working AC. Charged it and it worked for a day till I found a hole in the condenser. I put on a new condenser and two new lines and recharged it. Now it blows cold for a few minutes then warm. If I shut it off for a while it will blow cold again for a bit and do the same thing. Have not been able to see if the compressor is still engaged while blowing warm but plan to look into it more tomarrow. Any ideas?
  3. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Anytime a system has a hole and loses all charge as well as opening the system for repair it will accumulate moisture in the system which the dryer or accumulator will accumulate moisture to its capacity, so the dryer/accumulator should always be replaced.
    There are many possibilities for your issue so more info is needed. Did you vacuum the system before charging? Did you monitor pressure readings with guages? What kind of shape are the evaporator and filters in?
  4. cowcatcher
    cowcatcher Light Load Member
    Sounds like it could be freezing up.
  5. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    After Peterbilt oreder a couple of the wrong ones, and then told me they could not find a replacement I said screw it on replacing the dryer. Peterbilt charged it so ya it was vaccumed.
    Bingo. The drain seemed to be plugged and the evaporator was freezing. I shoved a wire up the drain tube and a bunch of water came pouring out. Seems good now.
  6. MackDaddyMark
    MackDaddyMark Medium Load Member
    311
    167
    Jun 14, 2010
    Elizabeth, New Jersey
    I am having a similar problem both the Low pressure line and the filter are freezing up to the point where there is visible ice on the outside. Where is the drain? 96 378 Cat 3406C
  7. Grumppy
    3,089
    10,595
    Dec 11, 2010
    West Monroe, La
    This was my first thought...
