Ac Cluch not engaging
Discussion in 'Volvo Forum' started by 1source, Jul 18, 2014.
  1. 1source
    1source Bobtail Member
    43
    11
    Sep 26, 2012
    Old town ,AL
    Un hooked Ac clutch and put a test light on it and no power .Getting Ac fault clutch not engaging . can someone help
  3. 201
    201 Road Train Member
    12,272
    25,055
    Apr 16, 2014
    high plains colorado
    These questions never come up in the winter. Probably low on refrigerant. When the pressure drops to a certain level, a pressure switch in one of the lines, disables the system.
    whskypete and CougFan Thank this.
  4. 1source
    43
    11
    Sep 26, 2012
    Old town ,AL
    had it evact twice changed pressure switch and nonething happen.[QUOTE="semi" retired;4139687]These questions never come up in the winter. Probably low on refrigerant. When the pressure drops to a certain level, a pressure switch in one of the lines, disables the system.[/QUOTE]
  5. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    After the evac did you recharge it?
  6. 1source
    43
    11
    Sep 26, 2012
    Old town ,AL
    yes recharged twice still no power to the cluch.
  7. HotH2o
    4,098
    4,865
    Sep 23, 2012
    Might be the switch in the dash. Sorry I'm not much of a mechanic.
  8. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
  9. 1source
    43
    11
    Sep 26, 2012
    Old town ,AL
    yep fuses ok put a test light on them.
  10. Badcable
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Might have a wiring fault on the way to the connector, taken a look at the wiring up to the connector yet? I've seen the connectors work themselves loose from the wires, so check close to the connector first and see if you've got voltage.
  11. 201
    12,272
    25,055
    Apr 16, 2014
    I know this doesn't help, but I can't think of a more trouble some accessory in our vehicles. I think the biggest problem with A/C systems is non-use in the winter months. I had a friend that ran the A/C several times a week in winter,(mostly to remove fog on the inside, which I believe new systems do anyway in defrost mode) and never had any trouble.
