AC CLUTCH NOT ENGAGING
Discussion in 'Ask An Owner Operator' started by thecubantrucker, May 27, 2020.
  1. thecubantrucker
    thecubantrucker Light Load Member
    145
    89
    Jun 2, 2019
    alright guys new compressor about 1 month old clutch does not engage new hi and low switches new dryer and both expansion valves checked for power on compressor and on hi pressure switch both got power I tried jumping thr hi pressure switch with a wire and still not engaging sorry I posted here no replies under garage
  3. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Low freon, wiggle plug maybe directly wire plug, control switch, FUSE
  4. thecubantrucker
    145
    89
    Jun 2, 2019
    checked fuses and relays all good it's got freon
  5. AModelCat
    160,499
    How did you verify it has refrigerant? Only way to tell if the charge is correct is to recover it and verify the weight of refrigerant recovered.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
  7. Spyro2112
    604
    416
    Mar 17, 2018
    Go to the auto parts store buy a can and the fill tube, put some in and see if it engages, cost you 25 bucks
  8. Spyro2112
    604
    416
    Mar 17, 2018
    too much it will engage but bow warm
  9. thecubantrucker
    145
    89
    Jun 2, 2019
    I do got a set of gauges put them on and see if I get any reading with the ac on
    truckdriver31 Thanks this.
  10. Spyro2112
    604
    416
    Mar 17, 2018
  11. Spyro2112
    604
    416
    Mar 17, 2018
    There's a gauge on the fill tube won't be accurate,but it will give u an idea
