Ac compressor works but not cold
Discussion in 'International Forum' started by vicdsm, May 6, 2018.
  1. vicdsm
    vicdsm Bobtail Member
    28
    8
    Mar 10, 2009
    new york
    So i will do resistance test on thermistors tomorrow but from im reading bad thermisters cause compressor not to kick on . Now i turn ac on compressor kicks on fan also kicks on keeps running but no cold air , line by reciever dryer starts to get slightly cold but thats it.. pushed in shrader valve i dont remember freon being so slimey oil like. Saw lots of dye come out but def has freon also
    . compressor looks very new .. maybe to much compressor oil? Any ideas??
    09 prostar sleeper
  3. 7seriestv
    7seriestv Light Load Member
    230
    144
    Jan 28, 2016
    Your problem is it's a prostar, it will start working in a couple days...
    Just kidding but my prostar do that and my buddy having the same issue with his prostar as well, it will work fine then one day out of nowhere it just stop working, then one day it start back working again.
    Check to make sure you do not have too much freon in the system, also makesure you have enough
  4. Heavyd
    Heavyd Road Train Member
    7,756
    6,195
    Feb 4, 2009
    Few things. Your Prostar will have lazy ac temps for two reasons. First, your main cab air filter, if it's dirty, it restricts flow over the evaporator. Second, the lower kick panel in front of the passenger seat is actually the lower blower box cover. It is very easy to mis-align this panel to the slots when reinstalling it causing warm cab air to be sucked in and around the evaporator instead of going through it. So have a good look at it and make sure it is installed properly.
    After that, I highly recommend having someone with Diamond Logic builder connect to your truck to see what the ac temps and pressures are doing. Taking resistance readings at the thermistors is fine, but that doesn't show the whole picture in case the wiring is bad somewhere else and the body controller isn't seeing proper values. Connecting an ac machine and checking the charge is also a good idea to make sure it is also proper. 3 pounds with a sleeper, 2.5 with a day cab.
