AC doesn't work while idling Peterbilt 579
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Edjahman, Aug 3, 2018.
  1. Edjahman
    Edjahman Medium Load Member
    648
    444
    Apr 2, 2013
    Hi.
    I have a 2016 Peterbilt 579 and the AC quit working while I'm sitting still.
    It sorta works while I'm driving down the road but it seems to be fading.
    Any ideas?
    I'm taking it to a TA shop because Peterbilt is closing soon. I just wanted to compare what you guys have to say with what TA says.
    Thank you for your replies!
    BUMBACLADWAR Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    is your engine fan running while the a/c is on?
  4. Edjahman
    648
    444
    Apr 2, 2013
    It doesn't seem to be cycling while idling like it normally does.
    I usually fast idle, 1000 RPM and I'll switch the fan on manually because it's easier on the fan clutch from what I understand.
    Even with the fan on manually, it's hot.
  5. Edjahman
    648
    444
    Apr 2, 2013
    Going down the road it's kinda working but it seems to be in and out. It's not so bad while driving really.
  6. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    you got a fan over ride switch?
    if so, turn it on, and see if that improves the a/c out put.
  7. buddyd157
    13,582
    34,896
    May 25, 2017
    under a shade tree
    for only a 2 year old truck, it could be low on freon, but the radiator need lots of air going thru it with the a/c on.
  8. Edjahman
    648
    444
    Apr 2, 2013
    Yeah it's kinda only halfway working while driving down the freeway with either the fan on or off and nothing while idling
    I tried it with the fan switch on and maybe it's a tiny bit better.
    It's barely enough only while driving at freeway speeds with the fan on or off.
  9. Edjahman
    648
    444
    Apr 2, 2013
    Would it just naturally need a recharge after almost 2.5 years or maybe it's leaking?
  10. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Yep, sounds like a leak. With the engine running and the A/C on, watch your compressor clutch. If the compressor cycles off more than it cycles on, then it's likely that you've got a leak that has allowed most of the refrigerant to escape.
    Hammer166 Thanks this.
  11. Goodysnap
    Goodysnap Road Train Member
    3,744
    9,105
    Jul 12, 2017
    You may want so stick with Pete on that one. The HVAC on that model is computer controlled with faults read through ESA. There are 5 actuators in the dash which are prone to failure and control everything from the duct temp to air flow. Does the blower ever shut off randomly? ,or is it just blowing warm?
    Worth a shot to at least check the refrigerant charge and for dye leaks. If its low it has a leak somewhere. Check the filter too. Easy access RH side under the hood on the cowl. Slide open door. They plug up real fast in dusty environments.
    Oxbow Thanks this.
