hey guys! Quick question, my truck was recently loaned out to another driver. It came back and the AC/Heat won't turn on. I'm not at work and wanted to get home but I was thinking that it sounds as if a fuse has blown. I'm thinking this because it won't even turn on at all. It's a Mack Pinnacle 2013. Any ideas. Thanks and stay safe!
AC fuse?
Discussion in 'Questions From New Drivers' started by RogerThat72, Jun 18, 2016.
Blower motor could've went out.HAd that happen several times
BUMBACLADWAR Thanks this. -
Does it blow?
Don't know the newer smacks very well, but the fuse panel should be pretty clearly labeled. You'd want to look at fuses and relays which say "HVAC Blower" or something to that effect.
Works on 1-2-3. 4 is a no go
Been busy sorry for the late response. Sound like a blower going bad or possibl switch? Thanks -
Sounds like a switch. 1, 2, and 3 will go through a resistor… usually, you'll run into the opposite problem, where the high setting is the only one which works after the resistor fails.
RogerThat72 Thanks this.
