my ac is blowing hot air. I just replace the ac condenser and the ac evaporator because they where damage and had a hole through both parts I replace both parts and did a ac recharge and it’s still blowing hot air and also my check ac light is on . The mechanic said it could be a sensor or a bad wire. I have a 2007 international ihc with a Cummins ism engine need help thanks
Ac help
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jpgale22, Jul 17, 2019.
Dumb question but have you checked the fuses? Is the clutch kicking in?
Did you replace the filter? Did you vacuum it down and leak test?
Intothesunset Thanks this. -
Also expansion valve could be stuck !
If you do not have this equipment don't bother doing work yourself.truckdriver31 Thanks this.
If it’s an international always check your thermisters, they’re the little sensors on your ac lines with white caps , if those fail then the system won’t work
hey i have a leak. let me put a 5 cent o ring in it and just empty 15 cans of freon in it. turn it on and it blows hot air. do it right from the start and you will have ice cold ac
yea that humidity done broke that bag in the dryer. bead charged threw system into expansion valveDeere hunter Thanks this.
