AC high pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Samot, Jul 15, 2020.
  1. Samot
    Samot Bobtail Member
    44
    7
    Mar 5, 2009
    Georgia
    I have a 2004 Pete 357 and the high pressure is at 350. The fan doesn't shut off at all, I've changed the fan switch, orfice tube, accumulator and blew all lines out but condenser. Am i missing something ?
  3. jamespmack
    216,333
    Over charged or blockage.
    Dino soar and Rideandrepair Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,749
    9,119
    Jul 12, 2017
    Radiator blocked with debris? Does it hold a rag?
  5. Ironmyke
    Ironmyke Light Load Member
    61
    57
    Jun 18, 2017
    Kansas
    That doesn’t say much, you didn’t mention the ambient temperature and humidity. However, you could put a set of gauges on there check the static pressure as soon as you turn it off. It should not take no more than 5 minutes for both the high and low sides to equalise. If I takes longer I would replace the TXV ad dryer.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Shoot temp gun on condenser, sounds restricted.
    Rideandrepair Thanks this.
