AC not working, electrical
Discussion in 'Peterbilt Forum' started by kwforage, May 13, 2018.
  1. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    2005 379. Compressor clutch doesn’t kick on. Has freon. High and low pressure switches show closed, also jumped with a paperclip and nothing. Put a test light on high or low pressure connector when unplugged and the clutch engages. This led me to find I am not getting a ground to the AC relay in the fuse panel. If I manually ground the relay the clutch engages. I am assuming the high and low pressure switches create a ground for the relay when closed? Is there something else on that circuit I’m missing? Any other ideas?
  3. KwT800c15
    KwT800c15 Bobtail Member
    Iam having the same problem too. Did you find out what the problem es a?
  4. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    No, if I do I’ll let you know
  5. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
    Did you jump the pressure switches or did you put one leg of light on ground/hot and the other to the switch?
    Usually if you jump the pressure switches and the compressor starts that would mean you have a bad pressure switch or low on gas.
  6. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi Kw. Check your fuses for oxidation on the spades. Aluminum tends to oxidize over time and you will loose connection. I had lost a few gauges recently and s friend suggested changing the fuses. Put all new ones in and everything worked again. Also just recently changed my evaporater, looked like a birthday cake. 03 pete.
    Justrucking2 Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    so the ground on the relay from what i see in the diagrams comes straight from hvac control it goes thru both high and low psi switch goes to the bunk blower relay and then to the hvac relay, it might also be dash switch. chase the ground and see where its missing.
  8. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    So ground comes from the AC switch on the dash?
  9. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    it does not come from there it goes thru there. and then ac compressor has constant ground and it gets power as request to turn on and off.
    kwforage Thanks this.
  10. kwforage
    1,047
    472
    Jun 3, 2007
    Wisconsin
    It was the AC switch in the dash. It was dirty inside the the contacts weren’t working. All good now!!!
  11. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    well you got it figured out.
