AC ? On my 2000 freightliner classic
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bzinger, May 16, 2016.
  1. bzinger
    bzinger Road Train Member
    16,604
    65,851
    Dec 10, 2014
    omaha , ne
    Last week I had new compressor and receiver dryer put on and works great but now its dripping water on the pass side floor , I cleaned out the drip tube under the firewall but it's still dripping ...where do I proceed from here ?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You must remove the ft. cover of a/c box to ck. if the drip tube is still lipped over inside edge of box if a crack is found in tube a new rubber tube or put repair sealer in crack?
  4. bzinger
    16,604
    65,851
    Dec 10, 2014
    omaha , ne
    Thank you ! I'll start there .
  5. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Probably need to drain refrigerant and remove the evaporator. Those year and make trucks the evaporator clogs up big time as well as the drain area.
  6. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    This is what a dirty evaporator looks like. FLD120 are famous for clogging up. You need to take it to a shop that can recover your refrigerant and take the evaporator out and clean it properly.
      File size:
      207.4 KB
      126
  7. xsetra
    xsetra Road Train Member
    5,096
    6,946
    Aug 21, 2011
    Dirty??? That looks like a brick!
  8. Getsinyourblood
    Getsinyourblood Road Train Member
    1,264
    1,769
    Jul 5, 2014
    Retired. North Texas
    My old mechanic would take an air hose and blow out that drip tube really good. But you probably did that.
