Ac problem- 2002 model362
Discussion in 'Peterbilt Forum' started by dcwjr, Jun 13, 2014.
  1. dcwjr
    dcwjr Light Load Member
    58
    Jan 11, 2013
    No power to compressor, can power it up and it works fine, all switches test fine and temperature sensor in core test ok, where is the relay??? Is everything behind the dash behind the heater box(squirrel cages)
  3. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    Did you check the low and high pressure switches?
  4. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    Like Old Man said --would be the binary or trinary switch. The fan most likely has to be on.
  5. dcwjr
    58
    Jan 11, 2013
    Yes all the switches test ok there is no voltage to them, the dash switch functions also we cannot find the relay if it even has one- the breakers are behind the panel and they are ok also-
