AC problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by me myself and I, Apr 30, 2019.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    It only works when i move. When i stop i get warm air in few minutes. Clutch is engaged, hot pressure line from compressor is to hot to touch. Should fan kick in? When i set it at full blast, fan seems to run slightly faster, but its not completely on. If runs when coolant temp is high. Am i correct to assume that fun not running is a problem?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,897
    May 25, 2017
    under a shade tree
    usually the engine cooling fan comes on automatically when the a/c is turned on.
  4. Cookie931
    Cookie931 Light Load Member
    138
    72
    Nov 3, 2017
    What truck is this on? Pete's their is a high pressure switch that kicks the fan on only if pressures get so high. Also your confessor and rad could be full of dirt to a point where the air flow is not enough for heat exchange... wash it out. What are pressures thru ac gauges could be something as simple as low freon level. Gauges would tell you that. Just some point to start
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Your fan should cycle when the A/C is on. It's getting warm when you stop because the high pressure cutout switch is shutting the compressor off when the fan didn't come on and the pressure got too high.
    Rideandrepair Thanks this.
  6. Rideandrepair
    17,480
    56,691
    Aug 8, 2015
    That’s right, and my guess is You don’t have a fan manual fAn switch.The switch that activates the fan is probably bad. Typically when the a/c pressure gets too high. High pressure switch cycles compressor off, and fan switch turns fan on, until pressure drops to normal. The fan switch may be separate or in combination with the high pressure switch,known as a bianary switch. In the case of a bianary switch, both actions are controlled by same switch, for instance, compressor off and fan on. One or both sides of a bianary switch could be bad. Either way, Find out which switch turns fan on, and replace it.
  7. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Thanks guys. And its on '13 Cascadia
  8. lilillill
    5,642
    13,472
    Nov 7, 2007
    Then the switch is likely combined with another in a binary or trinary switch. I let my account on Freightliner lapse so I can't get wiring diagrams anymore.
    You can sign up for a free account on:
    DTNAConnect - Daimler Trucks North America
