AC Problem
Discussion in 'Peterbilt Forum' started by needtoknownow, Jun 19, 2014.
  1. needtoknownow
    needtoknownow Bobtail Member
    12
    Sep 14, 2013
    The A/C in my 2004 Peterbilt 379 was working great and then it stopped blowing cold air. the compressor works, the compressor clutch is new, the blower motor is good, dryer is new,full of freon. when I tried to let some of the freon out a grey foamy substance came out of the line. When I replaced the dryer the same grey foam came out of the lines. I would appreciate any help I can get.
  3. Trygg
    Trygg Light Load Member
    221
    187
    Feb 11, 2014
    The West
    Get rid of the grey foamy stuff. :biggrin_25519:
    needtoknownow Thanks this.
  4. popcorn169
    popcorn169 Road Train Member
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    Have you replaced the expansion valve? I drive an 07 Columbia with a CAT and it stopped blowing cold air. First it was the compressor then when it quit again I checked and the lines where frozen when I showed the mechanic he replaced the expansion and it is working fine.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    To much oil in sys. stoping up the works
  6. snowwy
    snowwy Road Train Member
    20,569
    13,294
    Jul 6, 2009
    it cracks me up how everyone TRIES to diagnose their problems.
    WITHOUT EVEN HOOKING UP A GAUGE to see what's going on.
    grey foam is air bubbles in the oil.
    youi could be over pressured. or under pressured. or you could have a blockage somewhere.
    GAUGES. best tool for diagnosis. found at any harbor freight for $60.
    pushbroom, needtoknownow and Chewey Thank this.
  7. Angelahsaw
    Angelahsaw Bobtail Member
    I need to know how to replace an AC dryer in a 2005 379 Peterbilt . Can anyone help me out?
  8. Rideandrepair
    17,357
    56,319
    Aug 8, 2015
    Grey foam could be contamination from last compressor failure.Even if lines were flushed very hard to get contaminants out of evaporator.
