AC switch/wiring keeping fan running
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by skman, May 16, 2024.
  1. skman
    skman Medium Load Member
    305
    121
    Aug 26, 2013
    Saskatchewan
    My fan keeps running when I start truck. In InSite data monitor it says AIR is commanding it. When I shut AC switch off in parameters and start truck....the fan is off.
    So I put it back to ON in parameters...unplugged the connector and used a paperclip and waited a few minutes....wouldn't shut off.
    I used my test light and had full light power on one pin...tried the second pin and it had dim light power. When I leave the grounded test light on that (dim pin)...it will shut off the fan. As soon as I pull it away...the fan starts again.
    I assume there's not supposed to be voltage on both pins?
    This started after getting a shop to fix my erratic coolant alarm. That seems good now but I have this problem instead lol
  3. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    You might want to post Truck make and model and engine for people to help.
  4. skman
    305
    121
    Aug 26, 2013
    Saskatchewan
    Good point!
    It's a 2016 Pete 389 with ISX15 2350
    Smellfunny Thanks this.
