Accelerating with the Jake on?
Discussion in 'Questions From New Drivers' started by shivver, Nov 20, 2012.
  1. shivver
    shivver Light Load Member
    103
    48
    Oct 5, 2012
    Pennington,NJ
    Will using the Jake while upshifting cause problems? I've been using it at highway speeds to keep off the brakes when traffic bunches up, but haven't had it on while climbing gears. I know I can easily get from 9th to 10th (EF 10 spd), but haven't tried it in slow traffic. Do I have to turn it on and off as needed, or can I just leave it on? My trainer's answer was a little vague, and I was too tired to press him for specifics at the time, but he keeps it on almost all of the time. I'm new, and am trying to build good habits from the beginning. Am driving a 2011 Cascadia (if it matters). Thanks in advance!
  3. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    I'm no vet, but I believe most jakes are canceled when accelerator and or clutch is pushed and they resume their duties when you stop touchin stuff.
  4. iamjeff
    iamjeff Bobtail Member
    9
    Nov 17, 2012
    it shouldnt cause a problem but you had better to be able to shift real quick as it will drop the rpms fast. On my older truck you could leave the jake on and if you rested your foot on the clutch it would not allow it to engage until you lifted your foot up.
    shivver Thanks this.
  5. Tin Can Man
    Tin Can Man Light Load Member
    54
    58
    Jul 21, 2012
    It'll cause the RPMs to drop too quickly when you let off the power.
    If you learn to do it without letting the pedal top out all the way, it won't activate the jake.
    On some trucks, the jake won't activate if the shifter is in neutral, so if you float a shift correctly, it won't activate it.
  6. shivver
    103
    48
    Oct 5, 2012
    Pennington,NJ
    That makes sense, Thanks!
  7. WRIGHTRACING
    WRIGHTRACING Heavy Load Member
    882
    251
    Jan 3, 2011
    Iuka MS/Muscle Shoals AL
    To learn with...do it with it off. I've seen experienced drivers fight shifting with jakes on in Cascadias but I always left them on and learned that way. Drove 13 speed 04 FrtLnr as well...same way. Just whatever your preference is.
  8. Joker85
    Joker85 Road Train Member
    1,465
    331
    Jul 3, 2010
    Phoenix Az
    My trainer taught me that way two years ago and still drive that way teaches you to shift faster. I'm in a pete 587 13sp. I see traffic I can go from 60 to stopped traffic to rolling at idle speed without ever touching the brakes. The goal is to stay rolling. Don't wanna just hit the brakes when you come up to traffic. Keep them wheels rolling and just jake it.
  9. fisher guy
    fisher guy Road Train Member
    1,993
    1,060
    Mar 22, 2009
    Ocala Florida
    if you are just starting out leave them off especially when loaded and on hills the sudden jerking around has the potential to rip drive line components right out of there respective holes practice when ur empty in the higher gears to get used to it and over time make your way down eventually u'll be able to jake shift with the best of them i got an 18spd and i jake shift from low all the way to 18th empty or loaded with 100klbs gross on...it just takes practice and feel. also dont do it at truck stop parking lots at night...people seem to frown on that when u got straight pipes haha dont ask how i know lol
    halfburn Thanks this.
  10. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    if you are new keep it simple, only use your jake on a down grade. that way people wont laugh at you in the parking lot, when you forget to turn it off. jon
    T...Street and AfterShock Thank this.
  11. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,376
    Jul 16, 2012
    Bentonville Arkansas
    If u run tags don't use j empty makes ur wheels skip lol
