Accert water oil exchange program?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GP1500SC, Nov 2, 2012.
  1. GP1500SC
    GP1500SC Light Load Member
    91
    32
    Sep 10, 2011
    mo
    A buddy of mines 2006 Accert started getting a little oil color in the water about a year ago, now it's started showing antifreeze in the oil analysis, and color is starting to turn into oil scum in water reservoir.
    First he disconnected the transmission cooler
    Then he replaced the engine oil cooler
    He just got the analysis results back and it is still getting antifreeze in the oil it's not enough to scum up the filler cap or the dip stick yet.
    Where should he look next? Pull the pan and pressurize water to see if a sleeve is leaking?
    any pointers would be great
    The motor has about 570,000 miles on.
    And turning the the freshly cleaned radiator scummy
  3. seabring
    seabring Road Train Member
    1,844
    1,883
    Apr 24, 2011
    Sounds simple but maybe head gasket?
    GP1500SC Thanks this.
  4. GP1500SC
    91
    32
    Sep 10, 2011
    mo
    Thanks kw9s
    I was hoping I missed the obvious
    or that reman oil coolers can be bad or such like because of the oil and water going both ways
  5. Buckshot7cz
    Buckshot7cz Light Load Member
    168
    26
    Oct 16, 2012
    Sandy Oregon
    i guess head gasket aswell due to acerts being weak head gasketed
  6. bourbonst79
    bourbonst79 Bobtail Member
    chicago, il
    Not sure, but what about air compressor???
    I have 06 Accert myself and just got my oil sample back from lab with higher Copper and silicon. No potassium or no Sodium. Bud I replaced Camshaft just before I put this new oil in. Any ideas?
