Accident -> log book problem. Please, need help!
Discussion in 'Questions From New Drivers' started by SunnyCat, Jan 15, 2011.
  1. SunnyCat
    SunnyCat Bobtail Member
    5
    Nov 9, 2010
    Rockford, IL
    Hi, my boyfriend called me this morning. He was making a U-turn and hit the car. It was a white car, sitting in a white snow. He just didn't see it.
    Nobody was hurt and the damage to the car is minor. BUT...
    He messed up with his log book about 11 days ago. He had driven more than 14 hours, because it was the only way to be in time.
    So... I'm so scared now. Is it really possible for him to go to jail for that??
    He said, police would check his log book for 8 days. That's what they told him. What if they check it for a few more days, is it possible?
    It's his first year in truck driving.
    What can be done? Is there any way I can help him?
    Thank you!
    Dark_Majesty_06 Thanks this.
  3. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    Only give them the 8 days.
    Also, never to do a u turn.
    Rerun8963 Thanks this.
  4. walstib
    walstib Darkstar
    Driven or been on duty more than 14hrs?...If he drove more than 14hrs, that's a real issue he needs to get on top of for his sake and others on the road...
    I hope it works out for him...
  5. SunnyCat
    5
    Nov 9, 2010
    Rockford, IL
    It was in the huge parking lot, from what I could undertsand, not on the road.
    If he give them records for 8 days, can they check it somewhere else? Like those scales on the truck stops.
  6. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    Normally, they only check them for fatalities.
    The field guys only have the right to 8 days unless you give them to them.
  7. elk
    elk Light Load Member
    66
    17
    Sep 19, 2009
    Pa.
    chances are he'll only have to give the ins.info.he's not gonna go thru a dot check.good luck and let us know how it turned out.
  8. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    If he did a u-turn on a road he will be fired. No driver should keep more than 8 days of logs in the truck. Mail them home. A driver is only required to keep 8 days of logs on him at a time.
  9. Bumpy
    Bumpy Road Train Member
    6,529
    5,257
    Jan 27, 2009
    New Ulm,MN
    And I bet after this no more 14+ hr days?? I have been there..
  10. SunnyCat
    5
    Nov 9, 2010
    Rockford, IL
    Thanks for answering!
    I'm not sure I could explain the situation good enough. I wasn't there with him.
    I've just send him a link to this thread, so he could come here himself and explain it better.
  11. walstib
    walstib Darkstar
    Hopefully he WELL documented the scene with as many pictures as possible...Plows have been known to bury cars...
