i was putting in oil and I accidentally drop a small piece of plastic inside my oil reservoir will it damage my truck or should I just get a oil change and drain all the oil so it can come out
Accidentally drop plastic in oil reservoir
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jpgale22, Nov 10, 2018.
Better to be safe than sorry. I would drain it into a clean bucket with a strainer and see if you can get it.
how big was it? there is a screen on your oil pickup so it won't get sucked up but if its big enough to cause a restriction on the screen you probably want to get it out of there, but if its big enough to cause a restriction it probably wont come out the drain plug.
Once you start the motor it's a lost cause. You pull it out when it goes in or that's it.
Some of the plastic/foam lid from the container cap? It isn't coming out.austinmike Thanks this. -
So you think it would be on the oil pan
More information would be helpful. Does your oil fill tube go straight into the crankcase or is it on top of the valve covers? What exactly was it you dropped in there?
As anal as I am I can't imagine it should be a problem if it's just a small piece of plastic
Cam Roberts Thanks this.
