Accidentally dropped engine oil bottle's cap in my diesel tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Garry Sahota, May 8, 2016.
  1. oldson81
    oldson81 Bobtail Member
    41
    15
    Apr 8, 2016
    If you try to fish it out with any tools or devices take special care not to drop them into the tank also :)
  3. MidWest_MacDaddy
    11,209
    18,924
    Feb 21, 2015
    South Carolina
    Newbie Question:
    Why does one add motor oil to their diesel tank?
    Thanks,
    MD
    JC1971 Thanks this.
  4. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Lets it flow into the engine better for increased mpg.... Amazing economy when you're hooked up to a tow truck!!
    Garry Sahota and Ruthless Thank this.
  5. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    The only thing you want in fuel tank is fuel. Everytime you get low in fuel you need to try and get this out. ASAP especially if the cap has any plastic or any other sealer(cardboard etc..) that may come out of the cap. IF it is just a cap about the size of a half dollar coin you may be ok but it still needs to come out. Small items or plastic can get sucked into the pick up tube and cause your engine to run rough or overfill that tank.
    Garry Sahota Thanks this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,731
    Jan 30, 2010
    keep stroking.
    Had a cap off a quart of atf fall in my tank years back. Didn't worry about it. 3 months later I started having issues with one tank sucking dry. Guess what that little cap was getting sucked up on the end of pickup tube. Get it out of there. It won't hurt anything but will sooner or later mess with you. I ran mine low on fuel then parked on a incline so the end of tank with fuel cap was lower, got lucky it floated to where I could see it. Took one of those three finger grappling rods with the button to operate it on one end and plucked right out.
  7. AModelCat
    160,012
    ^^^ Probably the best way to go about it.
  8. Garry Sahota
    Garry Sahota Bobtail Member
    37
    4
    Oct 6, 2015
    Brampton, Canada
    Thank you all for ur valuable suggestions... I will try to fish it out once i get home this weekend... Nd will update...
  9. Garry Sahota
    37
    4
    Oct 6, 2015
    Brampton, Canada
    These Pre emission or say pre dpf trucks were gem... Earlier they introduced ultra low sulfur fuel... To reduce emissions... Tht ##**ed uo mpg and more wear on engine. Adding motor oil , addup lubricant to diesel ...which was lost removing sulfur.... Engine runs smooth... More Mpg.
    But make sure u dont add this to dpf or def rigs.... Tht will clog ur dpf.... More issues.... Life will su*k .....
    Adding 1 litre to fill up is enough frm my experience....
  10. MidWest_MacDaddy
    11,209
    18,924
    Feb 21, 2015
    South Carolina
    Thanks... Learn something new every day.
    Stay Safe,
    MD
