ACERT C-15 284-5 Code
Discussion in 'Trucks [ Eighteen Wheelers ]' started by skippido, Aug 17, 2011.
  1. skippido
    skippido Bobtail Member
    Hartford, CT
    :biggrin_25513:Engine Coolant Divertor Current Low Code. Check engine light comes on and off. replaced Eng. coolant divertor Solenoid, but code still showing. Check engine light is not constant, it blinks a couple of times and then it goes out. Any ideas as to what else I should look at? Help!
  3. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    generally the wiring to the solenoid is what causes the code...it gets cooked from the turbo heat...then gets brittle....then its all downhill from there.....I generally unplug then pull wiring out and cut out bad section and extend wiring and route it away from turbos down to frame then turn and run with frame back to solenoid....then no more problems....RW
  4. skippido
    Hartford, CT
    Thank you Robsredford. I did ovrlay the wire and it seem to make the hard code to go away, but it was still giving an event. I ended up finding an open circuit that might have the cause after all. I appreciate you sharing your ideas, thank you again!
