Acert c15 475 updated to 550.
Runs rough knocks rattles shakes under load no smoke of any kind while this is happening.
Over head done last month. Has a tapping noise also when it runs rough.
Any ideas please.
Acert cat problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dapper Dan, May 6, 2016.
Page 1 of 3
Runs fine when not under a load?
Any codes/check engine light? -
No codes only under load
The tapping noise makes me think that something has come loose, possibly from when the overhead was done.
4 weeks ago
The thing shakes knocks hardly any power
I wonder if a dead injector would cause that, I know they'll make it shake.
I have no clue just trying to keep from taking it to cat to get raped.
Take it to a Cat shop or buy the tools and do it yourself. It sounds like you need to do it ASAP before you grenade your motor. I found there are very few truck dealer mechanics that have a good understanding how to do an overhead on an Acert Cat.
Kenworth of Dothan, AL did an overhead on mine... never again. They missed two broken rocker studs on 5 and 6 and royally screwed up the adjustment. The jake was popping back and had no holding power and it rattled and ran like crap.
I got it back home, pulled the valve covers and VVA housings, and found the broken studs which they should have seen if they actually did the adjustment right.
Long story short, I bought all the tools to do it myself, replaced all the rocker studs and it ran like a champ. -
Tapping noise under a load on an Acert is likely a broken rocker stud.Oscar the KW Thanks this.
Page 1 of 3
