Hello, I have a acert in a 98 KW. It doesn't have a ecm as the shop lost it. There no longer is a sticker on the drivers side of the motor, nor on the oil cooler. As there is no way to find the engine serial number from the vin as acerts were never installed in 90s KW. Where on the block would the serial number be stamped?
acert serial numbers
Discussion in 'Trucks [ Eighteen Wheelers ]' started by canadianredneck, Dec 4, 2014.
usually on the passenger side of block about top of frame level 6inches from the back of block. if the cam sensor is behind air compressor and not on side of front engine cover it is a bxs. it takes a 70 pin ecm for that configuration but not like what is on the other mbn's, 6nz's or older. the 70 pin ecm for the bxs is built specific for the bxs. they look the same but are a different breed. the newer a-certs mxs and nxs use the 120 pin ecm's. there might be someone else on here that knows where else to look on block that will be along shortly.
that 98 w900 should had 3406E. The serial number can be anywhere. They usually of the right like superhauler said.
I wish it still had one, i cant understand why anyone would put an Acert in a truck period. I woulda put in a B model loooong before the Acert. Purchasing a new ECM and they want a serial number to program it. I know it has a upgrade injector kit in it. I m a thinking programming it to a 500. That should be a good set up. I will probably give them a NMX serial number.
Passenger side of engine. Towards the rear of engine block. Just above the oil galley. Grind the paint and rust off. S/N starts and ends with a * symbol. Newer engines, the numbers will be a dotted number stamp style. Good luck. The engine S/N will allow the dealership to look up the 'as shipped' parts list. Which will include the ECM software part number.
