active fault code? 2010 Cascadia/DD15
Discussion in 'Freightliner Forum' started by abenaki, Jan 22, 2014.
  1. abenaki
    abenaki Bobtail Member
    29
    4
    Jan 22, 2014
    Getting active fault 2010 Cascadia/DD15.
    fault code is: ENG Oil Pressure
    Sht Hi 128 100 03. Also oil pressure gage is at 0 but oil is still pumping through engine.
    Any help would be appreciated to help isolate my problem.
  3. FLATBED
    FLATBED Road Train Member
    Possibly a faulty oil pressure sensor as it feeds info to the pressure gauge ( 0 PSI ) as well as the ECM ( ACTIVE FAULT ) or the oil pump has failed / clogged and unable to pump proper pressures.
    abenaki Thanks this.
  4. abenaki
    29
    4
    Jan 22, 2014
    Thanks for your reply. I hope it's just the sensor. Not sure where it is.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    check wiring to MCM unit
  6. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Check it with a manual gauge.. There has been a few issues with the pick up tube o rings. I wouldnt assume that oil pressure is ok
  7. abenaki
    29
    4
    Jan 22, 2014
    Thanks all for your suggestions. It was the oil pressure sensor. A $31.93 part. Not bad. Again, Thanks.
    FLATBED Thanks this.
