AD9 dryer purging every 2 minutes
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tj379, Jan 30, 2024.
  1. tj379
    tj379 Light Load Member
    234
    224
    Nov 10, 2019
    ontario
    hello!! my ad9 dryer was purging every 2 minutes..3weeks ago..... so i just put a new one on it just cause! and it was fine, purged normal, now today 3 weeks later it started purging every 2 mins again?my air pressure dont drop on gage either side, but i can still here the dryer purge ? my compressor is a tu flo 501 with the unloaders in head that come out threw intake on side, i removed em tgey looked clesn snd the orings looked good, could my governor be bad? i assumed the governor just controled cut out? any suggestions to testing procedures would be appreciated..... or possible bad 3 week old ad9 ??
  3. Last Call
    Last Call Road Train Member
    7,568
    45,902
    Mar 15, 2021
    You didn’t put a new governor on when you replaced the drier ?
    Jordonh and JB7 Thank this.
  4. tj379
    234
    224
    Nov 10, 2019
    ontario
    no i did not... ill also add the dryer i replaced was 2 yrs old and i took it apart.... everything on it befor it went forva core and looked fine inside,, put back together bench trsted it, with 2 lines and purged fine, i said F it replaced with new one anyway thinking it wasnt the problem... but it was .. for 3 weeks anyway
    Last Call Thanks this.
  5. Last Call
    7,568
    45,902
    Mar 15, 2021
    It’s possible the governor is bad but it’s funny that the governor worked ok for three weeks then started acting up again there cheap and easy to replace I would try that
    tj379 and JB7 Thank this.
  6. JB7
    JB7 Heavy Load Member
    837
    1,331
    Dec 13, 2022
    Laurel, MD
    Yes, replace governor (#3 on troubleshooting list) as Last Call suggests as that should have been done when you replaced the dryer. If that does not solve your problem then check for leaks as that is the #1 cause. See pg 20 of attachment for troubleshooting.
    Oxbow, Last Call and tj379 Thank this.
  7. tj379
    234
    224
    Nov 10, 2019
    ontario
    ok ill give the gov a change n see !! thanks
    Oxbow Thanks this.
  8. SmallPackage
    5,503
    17,534
    Dec 20, 2019
    Marion Texas
    This last summer I guess due to the 2 months we had above 100 degrees the purge valve on an AD-9 on one of my trucks started causing the dryer to purge every minute or two and sometimes just stick open for a few seconds or more. Before I was able to gather one up to replace it would sometimes stick open at first purge and i’d have to turn the bolt in the center of the valve to get it to stop. It would sometimes go a day or two like it was fixed and then act up again. It would purge like you are describing at full psi in the system without the compressor even needing to be pumping.
    tj379 Thanks this.
  9. tj379
    234
    224
    Nov 10, 2019
    ontario
    ... my purge valve is sealing up tight as the old dryer was allso, nice sharp purge just to often .. grabbed a new gov this morning gonna put on later today... i wont be goin out again til monday but i will report back either way with the findings!
    SmallPackage Thanks this.
  10. tj379
    234
    224
    Nov 10, 2019
    ontario
    put a new bendix govener on... still purges every 2 minutes, 1 line off gov to to dryer to signal it to spit ... the other from wet tank to gov had air pressure when i took it off ... tellin me theres no leak in that line, new unloaders commin this week i figure put thise in if still purging every 2 min got be a bad new ad9?? thoughts
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,486
    6,532
    Aug 26, 2014
    Does the compressor cut out at the same time the dryer purges? If not maybe unbolt the governor from the compressor or unhook the line from the governor to the compressor cut out port. There should be air coming out to open the unloader valve in the compressor.
    If you have that is the compressor still pumping air out the discharge port when those parts are reconnected?
    If so maybe get a cheap air pressure gauge, 1/4" plastic tubing and some fittings. What is the air pressure in the wet tank when this is going on?
    If that stays above cut in pressure tee it in at the governor on the line from the wet tank. Is that pressure is consistent above cut in? Tee into the dryer control line and check that.
    I have never seen a Bendix do this but several Wabco's. The unloader valve in the head would mess up and the compressor would never totally stop building air. Then the dryer would purge often. Also one with a collapsed braided air line to the dryer on an older KW with a Bendix compressor. It did some funny stuff that would come and go.
    tj379 Thanks this.
