Adding a sleeper to a Freightliner Coronado day cab
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ghostzapper, Nov 3, 2017.
  1. ghostzapper
    ghostzapper Bobtail Member
    28
    4
    Nov 3, 2017
    Could a Peterbilt 579,389 sleeper be attached to a Freightliner Coronado day cab?
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    I'd say all is possible with the almighty dollars and a little creativity. The body lines may look odd.
    AModelCat Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,267
    26,724
    Mar 29, 2008
    TN
    I dunno.. A little bondo here and there and some elbow grease. That'd be a one of a kind. :-D
    Cottonmouth85 Thanks this.
  5. wore out
    wore out Numbered Classic
    15,845
    191,670
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Where the hell is y'all's sense of adventure. Throw some brackets on that the welds look like a grape vine pulled thru a hens ###. A home made rubber boot outta expandafoam and flex seal, leave it a different color and call it the Johnny Cash
    Broke Down 69, Grubby, bzinger and 6 others Thank this.
  6. 201
    201 Road Train Member
    12,272
    25,055
    Apr 16, 2014
    high plains colorado
    nightgunner, Grubby and Hurricane69 Thank this.
  7. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    anything is possible. I used to use inner tubes to replace boot between cab and bunk. Paint will make the unit blend in. Warsaw-20131026-00662.jpg
    Grubby, TallJoe, wore out and 3 others Thank this.
  8. AModelCat
    158,338
    Just Red Geen it. 10 rolls should do it.
  9. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Don't be silly, a pre-cab sleeper is just a waste of money. Save your cash and build one from plywood.
  10. Ridgeline
    22,365
    115,986
    You can do it but you need to add a flange and boot to the cab, better just to deeply the truck and buy one with a sleeper.
  11. wore out
    15,845
    191,670
    Jun 5, 2013
    What would it take to get that little unit bought today I wonder
