Adding coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chris50, Jul 1, 2016.
  1. Chris50
    Chris50 Medium Load Member
    346
    215
    Jun 21, 2010
    Florida
    I had to replace a coolant hose under the back of the cab and about 5 gallons of coolant drained out.. I caught about 95%+ of it. How do i go about getting all of it back into the system? Add to overflow tank? TIA
  3. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    add to the overflow tank and then run the truck to get the air worked out. You'll probably have to add some more afterwards.
    Chris50 Thanks this.
  4. AModelCat
    155,496
    If you've got a rad with a cap on the top tank, pour it directly into the rad first then top off the overflow bottle.
  5. Chris50
    346
    215
    Jun 21, 2010
    Florida
    Thanks for the replies. I dont have a radiator fill cap. I already poured all 5 gallons into the overflow and it sucked it up fine. Let it run with cap off till at operating temp to get any air out. Kind of seemed like a dumb question to me but really there was no other place to put it in... Was just making sure there wasnt anything I hadnt thought of...
  6. BigPerm
    BigPerm Medium Load Member
    Always check & top off cold/morning w/heater control to hot"...so it fills the hoses& heater ore.. It will eventually bleed the air out
  7. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    You. Don't have fill cap? What the hell kind of engine you are running pray tell? ALL radiators with coolant have a fill somewhere.
    As noted by others there is a alternate at the overflow tank. Keep feeding coolant into it as you run the engine. You need to make sure you feed coolant into it until the air quits escaping.
    The next problem will be a pressure test to be sure you are at the correct pressure once you reach operating temp. And keep adding coolant until your system stabilizes.
    You can tell if there is a fluid issue due to air in the block when the temp sensor starts to cause the temp reading needle to pulse. You will literally see it.
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Even the newer trucks with no radiator cap, and have to be filled from the reservoir tank, have bleeder valves on the upper radiator hose. Just unscrew it, fill the reservoir until coolant starts coming out the valve, tighten it down and fill reservoir to max cold line. It is also a good idea to occasionally squeeze the flexible portion of the upper hose several times to help get any remaining air out of the top of the engine. Then go ahead and go to work. Just watch it over the next few days and add coolant as needed. I have seen mechanics that didn't know that is what the bleeder valve on top the upper radiator hose is for and had to explain it to them!
    x1Heavy and Chris50 Thank this.
  9. Chris50
    346
    215
    Jun 21, 2010
    Florida
    Its a 2007 C15, engine says 2006 on it if that matters... No caps on radiator.
    x1Heavy Thanks this.
  10. Chris50
    346
    215
    Jun 21, 2010
    Florida
    Im afraid to turn the bleeder valve, might break off... almost 900k miles and its never been touched.. I have a 2200 mile trip over the next 4 days so i will just keep my eye on it. Thanks
