Adding coolant..
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SwishDawg, Mar 6, 2017.
  1. SwishDawg
    SwishDawg Bobtail Member
    20
    17
    Mar 6, 2017
    I have a truck, 2017 Pete 579. It has 4000 miles and is low on coolant. I see no leaks. Is that normal for a brand new truck? I mean I had a 2014 KW with well over 400k that I had to refill regularly, but that's a older engine. Maybe it's just a KW and Pete thing..
  3. MysticHZ
    MysticHZ Road Train Member
    5,902
    5,726
    May 28, 2010
    You should never have to put in coolant in a pressurized system. If you're losing coolant, there's a problem.
    Cam Roberts and flood Thank this.
  4. gpf87
    gpf87 Heavy Load Member
    765
    882
    Feb 2, 2017
    So many things could be happening , from a simple cap not holding pressure causing the coolant to boil out, or a simple( PLASTIC!!) hose clamp or hose itself, or it could be something severe like an egr cooler leaking , to head gaskets .. The cooling system needs to be pressurized and maintain pressure to keep the boiling point up, this is why you see the psi on the cap, for every psi you gain XX temperature in boiling point ( don't remember the formula)
    If it's a 2017 just use the warranty and take it to the dealer.
    It's never "normal" to have to add coolant , be it a 2000 truck with 800,000 miles or a 2017 truck with 4,000 miles
    Just passing by and KB3MMX Thank this.
  5. Jace379
    Jace379 Light Load Member
    146
    97
    Mar 6, 2017
    Remove the oil pan and get a pressure pump that fits the radiator cap and pump it to like 15 psi and see if it comes out, might be as simple as the water pump. seen it before but that was on a few 1998 to 2004 cats, also is the engine oil getting a bit white or milky looking
    KB3MMX Thanks this.
  6. Aaabbbccc
    Aaabbbccc Light Load Member
    Our yard has put on about 20 579's in the last three months. Every one of them has required coolant to be added. They're new trucks with air in the system. Fill it, keep detailed records of consumption , do a super thorough inspection for leaks.
    SnowMan24 Thanks this.
  7. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    There isn't a truck in the states that doesn't require coolant on a regular basis. It's VERY normal to have to add coolant occasionally.
    Freightliner was shocked when i took my last FL in for oil change. And it went 100k miles before needing a top off. According to them. It should require a top off every 50k miles.
    I was on the road for 6 years. drove Kw's, Pete's, and FL's. from 1996 to 2017. They all needed topping off when they lasted that long without coolant repairs of some sort. My 99 Pete dump truck i drove for 7 years also needed topping off. It only had 125k when i jumped in to her.
    I didn't think it was normal either. But my last 2 trucks were new FL's. 13, and 17 model years.
  8. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    First cold morning (below 30 degrees F) after it sat all night [off], chances are you'll see some red fluid on the ground somewhere. "Cold weather leaks" at various hose clamp areas are common on new vehicles and trucks. Be sure to check the coolant path back to the APU if you have one.
  9. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    This is very bad info. Sounds like dealership kool-aid. Coolant is like power steering fluid, in that the levels should remain the same unless there's an external or internal leak of some kind. I mean, veteran drivers, correct me if I'm wrong
  10. Jace379
    146
    97
    Mar 6, 2017
    I fully agree with you hopeovermope. yes alot of trucks have tiny leaks that can add up over a long time but it's dumb to think that it's normal for antifreeze to just disappear like the truck is burning as fuel. there's only three possibilities, it's leaking out into the environment, the oil, or running through the engine and out the exhaust.
  11. snowwy
    20,590
    13,308
    Jul 6, 2009
    Coolant disappears. Aint nuttn anyone can do about it. Think how much it expands when you're climbing hills. Then contracts when you're going down. Think about the air pressure as it gets hotter. And colder. And as texan mentioned. Think about the contraction of the seals when things get REALLY cold. You're bound to find some pissing. Both FL's i drove had a habit of leaking at the def tank. In january.When shut down.
    Coolant systems aren't sealed tight. They DO have a overflow at the cap or some place. Most of your coolant lost, probably happens climbing hills when fluid expands and air pressure builds up and gets higher. It's small and will take time before level drops are noticed. But imagine if there was no pressure release.
    Every time both FL's got topped off from the mechanics. They were plum full. They had no room for expansion. I was waiting for something to blow up. I don't know about other trucks as to wether they had plastic see through reservoirs. The trucks i drove were older and didn't have them.
    Oxbow Thanks this.
