Adding Jake brake to 12.7 S60 Detroit DDEC IV
Discussion in 'Trucks [ Eighteen Wheelers ]' started by allisonisatranny, Sep 8, 2016.
  1. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    Is there any information regarding this? I know that DDEC IV(4) controls the jake brake, but I am not finding out information about the wiring harness.
    Is there a separate wiring harness for the jakes? Is the harness already under the valve cover? Do I need a new wiring harness? Or is there a port on the harness for the jakes to simply plug into, like connecting a strand of Christmas lights to another?
    I'm not familiar with jake brake installation, but is this as simple as removing the valve cover, removing some bolts on roller rockers(or related) and bolting them on?
    If anyone has any information, this would be appreciated. Thanks.
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Wiring is in harness. Some engines if memory serves correct you need rocker arm mounts. I dont think this applies to all engines. Its been a while since I messed with one. But they are not too complicated.
    allisonisatranny Thanks this.
  4. allisonisatranny
    188
    131
    Oct 6, 2014
    I'm looking on eBay, and a set of used jakes seems steep for $2,000.00. I'd really like to figure this one out. Thanks.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    wiring may or may not be in your existing harness -- it was not on my MK...
    There are 2 or 3 different models of Jakes for the 12.7 so be sure you get the correct ones.
    $2000 for used is steep. A new pacbrake retrofit kit with switches and wiring costs that...
  6. jdchet
    jdchet Medium Load Member
    540
    769
    Sep 3, 2012
    NE Ohio
    I had a 2001 S60 12.7 that had a Pacbrake added to it and it was the worst engine brake I ever had in terms of reliability! Parts seemed to be hard to come by and had multiple problems with it. JMHO!
    JD
  7. allisonisatranny
    188
    131
    Oct 6, 2014
    I only want genuine "Jacobs" engine brake, not a "Pac" brake. Sound's like something you find on a motor home as a buttery fly valve 'exhaust' brake.
  8. allisonisatranny
    188
    131
    Oct 6, 2014
    I'll probably contact Detroit, these salvage yards over charge.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    haycarter Thanks this.
  10. orfordguy
    orfordguy Light Load Member
    56
    47
    Jan 21, 2017
    I've had several detroits.. I use Ddec 3 jakes on my Ddec 4 block.. i can try and find numbers tommorrow if need be.. all my rigs had jakes on them from factory so the harness was already there. I did have pac brake on one 12.7.. what a joke.. think running along side dragging my feet would be better.. swapped those for the Ddec 3 first chance I got.. heard about a guy swapping isx jakes onto a detroit but can' find proof so figure it's internet lore.. those are a set of jakes though isx hit hard..
