Hi everyone I just changed the tire size on my 02 KW. And can find almost no info on dip switch settings. The dealer is not very helpful. And I would like to think that someone has a setting chart for the dip switches. Instead of just changing the settings and hoping it works. Does anyone have one or know about where to start? Thanks Bill
Adjusting Speedo on 02 KW
Discussion in 'Kenworth Forum' started by Iron Pony, Aug 29, 2011.
Easiest way is to find a chassis the same year as yours that had the same tire size you have now, but were installed at the factory. Unfortunatley the only dip switch settings we have are all tied to each chassis. There is no sheet that lists all possible dipswitch settings for different tire sizes so dont come down to hard on us dealers. Although a request to PACCAR engineering through a 'Support Net' case may be able to get some help. Ask your favorite parts guy to make such a request and see what they come up with. All the speedo changes I have been involved with in the past were with mech speedos and involved a simple gear change. Or could be something as simple as a change in the software!
123456 Thanks this. -
JUST GET A DEALER TO HOOK UP THE COMPUTER TO it and set the proper parameters that you now have and the ecm will do the rest.
A new speedo comes with a chart see if the dealer has a speedo and photocopy the chart thats in the box.
rjones56 Thanks this. -
Well mine came with one but who knows why then cause I am assuming you work at a dealer by your name so you would know better than I.
