Advantages of third axle placement
Discussion in 'Flatbed Trucking Forum' started by Boneheaded, Apr 7, 2019.
  1. Boneheaded
    Boneheaded Bobtail Member
    30
    28
    Mar 8, 2019
    May seem to be a silly question to some. I am curious as to why do some trailers doing heavy haul steel have a third axle in between their 10'2" spread and some have that axle 10'2" in front of the spread.
    andhe78 Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    Deleted. Wrong answer
  4. johndeere4020
    8,522
    119,295
    Jan 1, 2010
    They’re different trailers for different purposes. The ones with axle in the middle can run as a spread or a tri for different freight. The one with the axle in front meet different bridge laws.
    That has nothing to do with it.
    Oxbow, snowman_w900, SAR and 2 others Thank this.
  5. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    Closed tri’s are considered an axle group 60k is the most they are allowed in most states. If each is spaced at 10’2 they are considered separate axle groups. In a lot of states they are allowed up to 22 to 25k per. So they are allowed 66-75k.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You would be looking at what I would call a Tridem instead of a standard 10' spread.
    For the small cost of a set of tires, the axle etc you can load a flat 60,000 back there on such a three axle set. At least in Arkansas. It would not turn very well.
  7. Humblepie
    5,077
    80,318
    Dec 25, 2018
    It turns fine.
  8. Boneheaded
    30
    28
    Mar 8, 2019
    It seems like most of the heavy haul coil/steel companies i am looking into here in northwest Indiana run 3 axle spread out 10' each, and a few run three axle grouped together. I had thought it might have to do with spacing of two heavy coils or just keeping the weight off the drives.
    cke Thanks this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    A typcial 10 ft spread can haul 40k legally. Throw in the 3rd tire in the middle and you've added 3500 lbs to the load. Minus the axle weight you're probably only gaining an extra 2,000 pounds.
    Seems like a few people mentioned that the load has to be NON divisible to be able to haul 20,000 per axle
    I haul liquid. Which is a divisible load. I can't go over 43,500 but my 3rd axle is also a drop and not a full axle with dual tires. Although dual tires could be installed on the drop.
    As for having the drop spaced out in the front. That would extend the bridge and allow more weight on the axle group.
    For instance. One guy just recently posted his trailer setup on this forum. He has 3 axles but he has what looks to be 2 feet between axles. He's not bunched up. Taking a wild guess and not knowing his bridge. He could probably haul 46,500 - 48,000 where as I can only haul 43,500
    This is all figuratively speaking of course. You guys on the east coast have some funky bridge and weight laws compared to us on the west coast.
    Should have posted this in the heavy haul section. Might get better answers from the guys that do it on a regular basis.
    cke Thanks this.
  10. Humblepie
    5,077
    80,318
    Dec 25, 2018
    That is a rust belt steel hauler setup. The handful of states they run in allow permits for multiple coils and large master coils.
    Oxbow, stwik, cke and 1 other person Thank this.
  11. Ruthless
    Ruthless Road Train Member
    9,186
    91,207
    Aug 28, 2010
    The City.
    What’s a master coil? Just a big coil? Or is there something else about it?
    I don’t haul coils now, nor have I ever.
    Oxbow, snowman_w900, stwik and 3 others Thank this.
