Advice about shifting 6-speed synchronized transmission
Discussion in 'Experienced Truckers' Advice' started by ronjohn, Aug 22, 2014.
  1. ronjohn
    ronjohn Bobtail Member
    12
    Jul 28, 2014
    Hi All,
    I am going to take my Class A test with a 6-speed synchronized truck. Is it true you cant really grind gears with this type of transmission?
    What are the best RPM Levels when down shifting. I would appreciate your knowledge ....Thank you
    I started on a ten speed but going to use a 6. Not sure if RPM is same.
  3. 8thnote
    8thnote Road Train Member
    1,980
    3,686
    Aug 12, 2013
    Chattanooga, TN
    A synchro transmission is just like what's in a car. No double clutching required.
    -engage clutch
    -move shift lever out of current gear and into desired gear
    -release clutch
    -repeat X6
    ronjohn Thanks this.
  4. moloko
    moloko Road Train Member
    1,569
    1,376
    Oct 26, 2012
    seattle, wa
    It's like shifting a car. Just push the clutch in and shift with the clutch depressed. Up shift when the engine tells you but on the 6 speed I think it's like 2100 rpm. Just listen to the engine sound though. Since it's synchronized I'm sure you could even skip gears with no grinding
  5. Ridgeline
    22,136
    113,459
    Wait a minute. YOU sure it is a syncro tranny? What kind of truck is it? FL series?
    I've got a truck with a 6 speed and it isn't a syncro.
    Yes you can grind gears in a syncro tranny.
