Advice from frequent snow drivers sought....
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Nov 12, 2022.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    'Tis the season for problem causing cold white crap.....
    I'm still a rookie, but I have come to the conclusion that OEM(Equivalent) wiper blades aren't good for anything but collecting snow and ice, which makes them totally useless when you really need them...
    That said, who has recommendations for heated wiper blades? Is there a universal kit, or are they generally specific to certain models? Is there a manufacturer with a website that can help identify what kit is designed for which trucks?
    I've got a 2020 Freightliner Cascadia. You'd think that with their parent company having roots in Germany, they would have a little knowledge about driving in the snow and how to maintain visibility, do they have a solution?
    Alternatively, how do you maintain your field of vision in that situation?
  3. tscottme
    tscottme Road Train Member
  4. Cat sdp
    Cat sdp . .
    21,199
    75,233
    Apr 8, 2012
    Orion's Belt
    It’s like a rear window defroster for the bottom of the windshield and the Sides….
    The plow guys turned me on to them.
  5. tscottme
    I never found a good solution. Some of the ideas sounded good, but they were pretty expensive like the heated wiper blades. The heated washer fluid seemed pretty clever.
    I settled for a very brief stop, like at a stoplight and just reaching out and pulling the driver-side wiper up and letting the springs slap it back down to the glass and breaking off some of the ice. I also tried to follow some advice from drivers before I went out West. Some drivers keep the cab of the truck cool or cold and don't run the defroster. The idea being a warm windshield melts the snow, the outside air temp (OAT) re-freezes the water into ice. The driver would wear warm enough clothes to stay warm. Some drivers also advised to wait until you REALL need to run the wipers and let them run for a sweep or two and then turn them off. If you run the wipers more than necessary, especially with defroster running, you just speed up the ice accumulation.
    I never found a good solution and I really wanted to find one that was cheaper than most alternatives and could be temporarily mounted easily on a company truck. O-Os have more flexibility on installing equipment. One of the things I tried was like a carboard shelf from the top of the dashboard reaching toward the windshield, but not in contact with the glass. The idea was to trap the warm/hot air from the defrosters down low on the glass where the wipers rest. It was OK. I think someone warned me or I was worried cncentraing the heat on part of the glass might make it more likely to crack. Winter driving is a time when you may more likely get nicks or dings in the windhsield from passing traffic kicking up "salt" or rocks from the road. The heating elements you stick to the bottom of the glass seem fantastic, but it seems you have to replace them each time you replace a windshield. Modern windshields seem to be thinner and more prone to damage than before. It seems I had one replaced almost each and every year for a while.
  6. Commuter69
    1,142
    635
    Jul 2, 2014
    I've asked my contact person at the office to approve this and help finding the right solutions for each of our trucks, even going so far as being willing to actually purchase them for this truck if he'd install them. As luck has it, I'm planning on being home for a few days early next month when I'm scheduled to start the process to replace my teeth.... while I'm off the road, I am going to put the truck in the shop to address a bunch of minor things, this included in the list.
  7. hope not dumb twucker
    5,898
    51,336
    Aug 23, 2022
    Tb0n3, tscottme, Bean Jr. and 2 others Thank this.
  8. okiedokie
    okiedokie Road Train Member
    13,416
    104,764
    Jun 13, 2011
    PNWET
    That's the way we did it in my neck of the woods.
  9. Dennixx
    Dennixx Road Train Member
    4,534
    14,555
    Feb 13, 2010
    twin cities
    We just switch out to "winter blades" with the rubber surrounding to prevent ice buildup. Helps a bit.
