Advice/hints/tips For Waitresses/waitstaff:
Discussion in 'Truck Stops' started by Powell-Peralta, Dec 20, 2007.
  1. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    First of all, i would like to say to anyone who comes in to work "after-hours" that you are awesome, i love you and you really don't need to read the rest of this post regardless of your situation. By "after-hours," i mean after normal busy times--after dinner and even overnight if it's a 24 hour restaurant. 3rd shift etc.
    It is because of people like you who come in and work late shift, that people like me can eat at later hours. And i would tip you good just for that reason. By people like me, i mean i am the type that does not like to shut down/stop driving until about 10pm to 2am. This makes it difficult to actually find a space to park; i often have to drive to the next truckstop or rest area before i can "get lucky" and find a spot. Not to mention finding a place to eat because most places are closed by then. But, thanks to people like you, i can and do eat quite well. And i sincerely love you for that. Please keep up the good work.
    Now, for the rest of you, here are a few suggestions, hints and tips i've picked up that could help make it easier and better for everyone as well as possibly increasing tip money:
    1) If you are going to clean off a table (and you should), here is the proper way to do it:
    a) Remove all the plates, cups, silverware, napkins, mats etc.
    wipe off all the debris---food trash etc. on to the floor or in the busing tray.
    b) Next, if you decide to wipe a table down (and you should) here is the proper way to do it:
    You should be using the proper cleaning solution with one rag. Windex is ok.
    Preferably, spray the table down and wait about 2 mins to let the enzymes in the cleaning solution do their job---to "eat" away at any germs, bacteria, dirt etc. While waiting, you could be performing another task at this time.
    Then, after about 2 mins, dry the table off with a clean rag or preferably clean paper towels. If you use rags, please do not mix the rag you use to apply to water with the one you use to dry the table off with. Also, these rags need to be changed often with new ones---like every 2 hours or so. Keep up the good work.
    The reason why you want to dry the table off thourougly (as in completely dry) is because bacteria love moistness. If the table is dry, bacteria don't have a chance to multiply. If you continually leave tables wet, the place will get nasty quick, guaranteed. If you cannot or will not for whatever reason dry tables off, it would be better not to wipe them down at all. Just remove the dishes and trash and then re-set the table.
    Now, if managment does not understand or require the need to properly wipedown tables, you need to tell them of this need. i know it is tough to approach managment in this way when you are working in a restaurant---i know i've worked at restaurants, but it is the right thing to do, also common sense dictates that a cleaner restaurant brings bigger tips and also we are counting on you. If you cannot get results from immediate managment (and it would not suprise me), then you go to the corporate level and girl, you DO NOT STOP UNTIL YOU GET RESULTS. If it's a private truckstop, you go to the owner.
    2) Silverware:
    a) There is simply NO EXCUSE dirty and/or stained silverware. If it's dirty, someone is not doing there job. i've worked as a dishwasher and i know the machine is capable of doing a good job of cleaning silverware. You DO NOT merely rinse silverware off. If you've run out of silverware, you tell the patrons that they will have to wait. And then you provide them with clean silverware.
    If the silverware is stained it means they weren't dried off. And they need to be dried off for the exact reasons stated above in #1.
    If you cannot or will not do either of the above it means you aren't doing your job and that you are a loser. i know that working in restaurant can suck, but you signed up for the job, you are being paid to do that job. So do your job properly. i know you are not a loser, so don't be a loser.
    to be continued.
  3. 2xR
    2xR Medium Load Member
    365
    94
    Dec 12, 2006
    Ol' North State
    Many restaurant service people only use one rag to wipe tables and don't worry about leaving moisture for the bacteria to live in. Why, you might ask? Chlorine bleach is why. That rag is wet with diluted chlorine bleach which kills all the nastiness and the longer it stays wet, the more killing it can do.
  4. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    Not acceptable; Still needs to be dried completely off.
  5. 2xR
    365
    94
    Dec 12, 2006
    Ol' North State
    See ya' at the Ritz... :yes2557:
  6. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I drink a lot of coffee. If a carafe is not left, please keep an eye on my cup. I will quickly empty it even when it is very hot!:biggrin_25514:
  7. myminpins
    myminpins Road Train Member
    1,578
    65
    Sep 20, 2007
    Dartmouth, NS, Canada
    Me thinks you are paranoid about germs!!! It's fine to wet wipe it if it's got bleach in it, as stated above. We don't live in a glass bubble, you know.
  8. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    Not paranoid; i just believe i and all truckers have a right to eat in place that is NOT infested with knats, is NOT sticky or greasy when we sit down, and/or does not stink, and any other negative thing(s), etc. etc..
    This ain't india, this ain't china; This is the USA.
    i'm suprised that you, as a canadian, would state something like that; Because Canada is actually cleaner than even the u.s..
  9. myminpins
    1,578
    65
    Sep 20, 2007
    Yes, it is and wiping down a table thoroughly with a bleached cloth is a perfectly acceptable way to clean a table. I don't see the problem with that, that's all.
  10. Powell-Peralta
    1,585
    240
    Jul 17, 2007
    You're wrong; i read a textbook on food service preparation and it clearly states leaving any surface wet is unacceptable.
    i will scan the text if nessesary.
    It is because of thinking like yours is why society is breaking down.
  11. myminpins
    1,578
    65
    Sep 20, 2007
    ROFL!!!! Whatever floats your boat!!!
    Germs are everywhere and being exposed to them is what strengthens the immune system from the time we are born. Desperately cleaning everything to death is CAUSING more problems than it is solving.
    You obviously don't understand medicine and science so I won't waste my time trying to explain further.
    Have a Happy New Year!!!!
