Advice needed: home time parking in winter
Discussion in 'Questions From New Drivers' started by crazw, Jan 27, 2014.
  1. crazw
    crazw Light Load Member
    122
    28
    Sep 10, 2012
    Buffalo, NY
    Live in Buffalo area and we are getting good snow this winter. I will be home for several days. Need tips on what can be done so that when I return to the truck I am not stuck in snow and need a tow?
    No I don't have luxury of parking at home. No I cannot park at a truck stop. No I don't have access to plug in vehicle.
    Please offer helpful info and not just find better place to park. It is what it is and that's all I have.
    How would you experienced drivers handle this? Oh I will be empty too...
    Thank you.
  3. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
    Get a shovel. Hire a plow truck. Get chains and learn to use them.
    As a last resort you could move to FL
  4. Chinatown
    Chinatown Road Train Member
    75,004
    171,005
    Aug 28, 2011
    Henderson, NV & Orient
    If the weather looks like it will be really bad, chain up before you go home, then you're ready when you return to the truck. At least you will be able to pull out of the parking spot to an area where you can remove the chains.
  5. crazw
    122
    28
    Sep 10, 2012
    Buffalo, NY
    Don't have access to chains. Any other suggestions?
  6. J_FROG
    J_FROG Road Train Member
    1,061
    564
    Sep 4, 2011
    49 states and Canada
    Stay home until spring...
  7. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Ask your company for suggestions. Sometimes they have other drivers living in the area with a good shared lot.
    Also check local shippers and receivers, sometimes has extra room.
    Drive around in your car, looking for large lots especially gravel lots and ask the owner of a lot.
  8. Newtrucker bak
    Newtrucker bak Light Load Member
    101
    53
    Oct 22, 2013
    Naples ID
    Drive around parking area to cool off tires before you stop so they won't melt into snow pack. Also if you have a little hill you can back trailer onto it will help you get moving when you take off. And kitty litter works for traction. Might throw a little down then park on it or throw some in front of tires before you take off
    crazw Thanks this.
  9. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Maybe ask some of the truck repair shops if they rent parking space. Another place I'd check is DeCarolis Truck Rental on Williams St.
  10. GoBlue487
    GoBlue487 Light Load Member
    77
    15
    Sep 18, 2009
    MI
    Also check around for storage facilities that have truck parking. I'm in the same boat and park at a storage place that is gated with plugins for each truck with an assigned spot. (About 15 trucks park here) Nice knowing you have a spot that will be there when you get back. Don't know how much it is as the company pays for it, but another thing to check out.
    crazw Thanks this.
  11. FLATBED
    FLATBED Road Train Member
    Get prepared if you find a spot to park , go to HOME DEPOT get a big bag of sand / salt mix ( better than kitty litter ) and a good shovel , line up a company for a possible boost to get it going after its sat for a few days, make sure you top up the tanks and add anti gel to the tanks.
    As others noted if you or someone at home can call around to storage places , repair shops to see if they offer short term parking get started on that before you get to Buffalo
    Start with this place http://www.brownsautostorage.com/
    crazw Thanks this.
