Advice on GPS that uses GPX files. What are you guys using. I have a Garmin drive 52
Discussion in 'Questions From New Drivers' started by Brandonva804, Feb 17, 2020.
  1. Brandonva804
    Brandonva804 Light Load Member
    128
    127
    Nov 15, 2019
    Recently purchased a gps unit Garmin drive 52 for use with local routes. It uses GPX files but it’s missing features I can’t find. Like tracks and the ability to use custom routes from basecamp.
    Not sure if this unit supports what I want but I’ve tried everything to route gpx route I saved with trackme.
    Which units are drivers using for route delivery’s?
    So I can put a gpx file on my Garmin but they are split into thousands of parts. And I can only use trip planner to find the parts and set it up. From what I’ve heard you can set it up so the gps only follows the given gpx path and that’s what I want. Advice.
  3. PE_T
    PE_T Road Train Member
    If you already know the route you need to take, it would be much easier to place “avoidances” on the Garmin map, so the GPS takes the route you want it to take. You need to look at your manual to see how this is done.
  4. Jonrulerofearth
    Jonrulerofearth Light Load Member
    232
    340
    Sep 1, 2011
    Hueytown, Al
    That's a "car" gps, you need to be very careful with that. Garmin offers the DEZL line of gps's for truck routing.
    Good luck.
    tscottme, lovesthedrive and PE_T Thank this.
  5. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Used a laptop with an aircard and pretripped the destination. With a grease pencil, wrote the directions on the windshield. GPS will mess you up, when DOT sees that you have the wrong GPS they will penalize your hide.
