advice on how to fix air leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by musicmann2u, May 2, 2010.
  1. musicmann2u
    musicmann2u Bobtail Member
    29
    Buffalo, New York
    Hello Drivers: I just recently bought a truck on E-bay, Got a good deal, I thought, until I received it without a passenger seat:biggrin_2552: Not A big deal but the 5/16 air line for the air ride seat was cut and a screw was put in it's place:biggrin_25510: Now I have a leak so bad I can't even build enough pressure to move the truck an inch. Can one of you guys please tell me what I can use to cap off this threaded pipe sticking out of the floor? I searched all day for a compression cap at all the hardware stores but no luck. Will this even work?
    Thanks for your help I really do appreciate it.:yes2557:
  3. tk40176
    tk40176 Light Load Member
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Why not just add one of those air blow gun - to clean out your truck interior? They're cheap and you can re-route the hose under carpet / floor mat to some place out of the way. Kill two birds with one stone.
  4. Rollover the Original
    Rollover the Original Road Train Member
    3,206
    2,712
    Jul 1, 2009
    Springfield,MO
    Go ant truck dealer and get a new a new replacement fitting that goes through the floor with a plug fitting for it and a roll of the white teflon tape. Go under the truck and remove the fitting and then replace the fitting or however it need to be removed from the truck and replace it with the new fitting and have the plug with teflon tape wrapped around it about 3 times installed in it. It should not leak any more. Then go find a new seat but never buy a truck off of EBay until you or a mechanic have inspected it!
    losttrucker Thanks this.
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    Some advice for next time. If you have an air line with no end on it that is leaking, fold the last few inches of line back onto itself and ziptie it togather. The kink in the line will make a great TEMPORARY fix.
  6. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I second that. I've bought them and installed them in several company trucks which of course you have to leave behind. Make's cleaning worth while though.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Fixing a air leak is easy, Finding the leak is the hard part!:biggrin_25522:
  8. HEAVY DUDE
    HEAVY DUDE Road Train Member
    1,388
    555
    Jan 5, 2010
    NUNYA
    Zip's or duct tape works every time.
  9. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    Mix dish-washing soap with water in a spray bottle....
    That's what I do....These old ears of mine have tinnitus and I can't tell if it's air hissing out, or the tinnitus...There's no mistaking bubbles though....
