Advice on Pulling Doubles
Discussion in 'Questions From New Drivers' started by rowekmr, Oct 15, 2020.
  1. rowekmr
    rowekmr Light Load Member
    89
    46
    Jul 9, 2008
    Chicago, IL
    I'm looking at 2 LTL's to start out with and both use double 28' trailers for their Line Haul positions. They both have training programs for drivers with low experience (me) but wanted to hear advice/experiences from those that have experience with before I start.
    jamespmack Thanks this.
  3. Blue Zombie Trucker
    Blue Zombie Trucker Light Load Member
    279
    681
    Nov 1, 2017
    Well, for starters, don't try backing them until you've got a bit of experience.
    MACK E-6, rowekmr, Bean Jr. and 2 others Thank this.
  4. azheavyduty
    azheavyduty Light Load Member
    288
    915
    Jan 11, 2011
    Glendale, AZ
    They are going to wiggle. Just go with it, drive normally. Before you pull in anywhere, make sure you can drive through. You're not backing out.
  5. '88K100
    '88K100 Road Train Member
    1,323
    2,907
    Aug 23, 2020
    Make sure the heaviest trailer is your lead. I made it a habit of always connecting my safety chains at convertor first.
    I had steady run, tandem wagons, beer lead, meat rear., 137K every night. I liked pulling them.
    rowekmr and jamespmack Thank this.
  6. rowekmr
    89
    46
    Jul 9, 2008
    Chicago, IL
    How much differently do they track in a turn vs a 48' or 53' which I have some experience with?
    D.Tibbitt and jamespmack Thank this.
  7. Cattleman84
    Cattleman84 Road Train Member
    9,925
    70,822
    Nov 1, 2017
    The Sticks, Idaho
    Ive never pulled double 28s... But I have pulled 42 with a 36 pup, and a 48 with a 36 pup... Neither of the really tracked much more than a 53 with the tandems all the way to the rear... Maybe like 3 or 4 feet more inside tracking on a 90 degree turn
  8. jamespmack
    215,789
    They turn shorter than long singles, and as @azheavyduty said they wiggle.
    One time I will tell you to watch the mirror less. If you focus on a empty pup bouncing around and try to counter act it. You will wind up in a ditch.
    As @'88K100 mentioned. Heavy in the front.
    If your stuck in a situation and have to back up, without experience. You can chain lead to pup, or dolly to lead. Its slow and labor intensive. But can save your rear.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,504
    9,788
    Mar 30, 2014
    I was in the mountains when I looked in the mirror. I saw one go this way and the other go that way. I decided to look in the mirror a whole lot less pulling doubles!
  10. jamespmack
    215,789
    I still remember towing my first set of doubles, then a set of triples behind a wrecker. Seeing a empty pup jump and sway scarred the heck out of me.
    D.Tibbitt, rowekmr and Bean Jr. Thank this.
  11. 201
    201 Road Train Member
    12,335
    25,216
    Apr 16, 2014
    high plains colorado
    Don't! I remember, my O/O job, they wanted us to pull doubles out of the rail. I got my endorsement, but told them I'd never do it, and to this day, I never pulled more than one trailer at a time. One was enough.
    MACK E-6 and Speed_Drums Thank this.
