Advice on pulling heavy loads........
Discussion in 'Questions From New Drivers' started by pa musky, Jan 30, 2013.
  1. pa musky
    pa musky Light Load Member
    63
    12
    Jan 3, 2013
    central PA
    Might be starting with a company that supports the natural gas industry on Monday.I'm told that some of the pumps they use can be in excess of 100,000 lbs.While I'm sure I wouldn't start right out pulling them,I may very well be doing that some time down the road as I gain experience.What advice do you have for pulling those types of loads?
  3. old timer123
    old timer123 Light Load Member
    54
    27
    Jan 29, 2013
    Villa Ridge,Mo.
    Just make dang sure you got the permits and they are right.and make dang sure u got ur load well secured.I use to haul steel coils up to 63,000 lbs.had no problems at all with them.10-4
  4. Dinomite
    Dinomite Road Train Member
    4,092
    4,308
    Sep 6, 2012
    Looking 4 Rocks
    Could smoke a nice set of brakes with 100,000 pounds on your wagon in those PA hills. I'd probably leave that to the guys with a little more experience.
  5. old timer123
    54
    27
    Jan 29, 2013
    Villa Ridge,Mo.
    use your jakes and drop ur gears and dont get in no hurry going down those hills and u'll be all right.the gear u use going up is the gear u use going back down depending on the grade.just take ur time and get the exp.10-4
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    What if the grade is different on the other side?
    keepitsimple Thanks this.
  7. pa musky
    63
    12
    Jan 3, 2013
    central PA
    Oh trust me I'm in no hurry to haul that much weight just yet.I figured slow and steady is the way to go for sure.I'll learn as much as I can from you guys that KNOW what you're doing!
  8. pa musky
    63
    12
    Jan 3, 2013
    central PA
    We pulled alot of hills while I was in CDL school and the trainers POUNDED IT INTO our heads to be in the right gear going down any grade.I would definately err on the side of caution no matter what I am pulling.
  9. fisher guy
    fisher guy Road Train Member
    1,993
    1,060
    Mar 22, 2009
    Ocala Florida
    remember the old saying u can only go down a hill once to fast but as many times as u want to slow and also u can never have to much securement.
    another thing to remember always take off nice and easy screw everyone else they are not the one thats gonna pay for the rear end you just disintegrated trying to take off from a red light
    easy off the clutch planned shifts, always make #### sure that shifter is all the way in before you put the torque to her
    in the mud dont EVER spin never be afraid to ask for a pull or a push if u have a trailer capable of being pushed i saw a guy ruin a set of 46,000lb full locking rear-ends, drive shaft and 3 axles at once all because he was to stubborn when he got stuck in the mud
    i dont care how heavy spec a truck is all it takes in one little mistake that u didnt think was a big deal doing in an 80,000lb rig to cause some real expesive damage and end up on the employment line
    pa musky Thanks this.
  10. tootie04
    tootie04 Medium Load Member
    424
    131
    Oct 8, 2008
    Tucson AZ
    My husband pulls HH and there are times we go 15mph or less down mountians...the best advise has been given make sure permits are right and dont be in hurry.
  11. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I'd look at it as descending at the right speed, rather than being in the proper gear. Yes, the two go hand in hand, but what's important is that you have enough braking available to come to a complete stop if needed - before the brakes overheat and fade away. For me, that means either maintaining a steady speed with engine braking alone, or stab braking for less than 5 seconds at no less than 45 second intervals.
