Advise type of oil for a 2003 C-15
Discussion in 'Ask An Owner Operator' started by manue, Mar 27, 2015.
  1. manue
    manue Bobtail Member
    14
    I just bought a 03 Kw T-600 with a C-15. Its previous owner told me he used to put 8 gal of Mobil Delvac and 2 gal of Lucas. What do you think about that mix? what type of oil do you recommend for this engine?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    don't waist the money on lucas. two gal. is a little extreme. I use to just put a 1/2 gal in when I did an oil change. then the price went up. cant justify the cost anymore.
    Cetane+ Thanks this.
  4. rollin coal
    rollin coal Road Train Member
    13,299
    26,877
    Mar 29, 2008
    TN
    Lucas is a waste of money. I ran Rotella 15w40 for a few years in mine then recently switched over to NAPA store brand 15w40 because it was cheap. Picked up a dozen 5 gal.buckets for $50 each. One oil is as good as another. Change it and the filter frequently and do regular samples every time you do. I dump my oil every 12,500 miles. Some people go less some go more. I think CAT says 300 hours is when it should be changed. My belief is changing it often is the cheapest over haul you will never need. But guys say it is wasteful and crazy. That's OK it's my money, my truck, i'm the boss man.
  5. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Straight Mobil Delvac should be all you need, there is more than enough protection in any oil made for diesel engines. Do regular oil samples and be sure your not getting any fuel dilution or antifreeze in the oil and you should be fine.
    MZdanowicz Thanks this.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Do you know what the viscosity of Lucas Heavy Duty oil Stabilizer is? 110 Cst @ 100 deg C.!!! By comparison 40 wt or 5/15W-40 is around 14-15 Cst @ 100 C. Even 250 wt gear oil is only >41 Cst @ 100 C. So your average viscosity running 1:10 lucas/15W-40 could be well into the 20s @ 100 C.
    I cant find the original article that I got this info from. I keet this little tidbit of info in an oil info document to remind me to never use ....
  7. MZdanowicz
    MZdanowicz Light Load Member
    221
    207
    Apr 7, 2013
    peabody, ma
    Hey Manue- It seems all the major brands are fighting to have the best. Of the Shell, Mobil, Chevron, Valvoline, I had good luck and continue to use the Chevron Delo 400 15/40 Super. My engine now has 16,600 hrs on it and only burn less than a quart on a long mission. Mike
  8. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Everybody I know is running Delo 400 premium (including heavy equip), if the motor isn’t on its last legs then Lucas or Power Punch is just a waste of money IMO.
    If you have a weak power steering pump, a lot of times that lucas/PP will lengthen its life.
  9. MZdanowicz
    221
    207
    Apr 7, 2013
    peabody, ma
    MrX- Your so right about the Lucas Steeing fluid! Kept me going and stopped a leak till I got home. I didn,t take down the unit untill one more trip.Mike
  10. tallmon
    tallmon Medium Load Member
    657
    320
    Oct 22, 2014
    Delo 400 here also. Our two oldest trucks have 1.8 and 1.5 million. PM every 15 to 20k.
    Walmart has it for 11.93 per gallon. Tractor Supply for about 13, TA for 19 doh!
  11. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    I actually have a 2003 kw t600.. Recent overhaul. Put delvac 15w40, no Lucas. Like said above, change it at regular intervals and change filters. How many miles on your truck?
