Ah! Stupid Idle Shutdown
Discussion in 'Questions From New Drivers' started by IROCUBabe, Jun 8, 2008.
  1. IROCUBabe
    IROCUBabe Road Train Member
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    I discovered a new thing to hate about the 387 I've been assigned. It has a idle shutdown thing after like 5 minutes. Not cute when its 90 or more outside. I so far have been unsucessful in managing to get it to stop.
    The cruise control only has set and resume. So thats out. Any other ideas before i buy a cinderblock for the gas pedal...
  3. IdahoPhil
    IdahoPhil Medium Load Member
    380
    85
    Oct 23, 2007
    Wild Wild West
    It's in the computer setup. A mechanic may be able to access the software and turn it off, they'd have to have the password to get into it though. I drove a Freightliner about 3 weeks ago with this same problem. It had a Cummins engine and the mechanic tried to edit the idle options but he didn't have the right password for the system. He called support, but the password they gave him didn't work either.
  4. dieselhound
    dieselhound Medium Load Member
    410
    39
    Mar 23, 2008
    Erie,PA
    Does it have a clutch? Does it give you a warning before it shut down? I've heard that when the light flashes press the clutch. I really don't know.
  5. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    There should be a light that flashes on the dash to alert of the idle shutdown. If you depress the clutch or tap the throttle it should disengage the shutdown sequence. Of course this is dependant upon the program settings.
    The simplest way to find out how your truck is set up is to ask someone in your company shop. They will know how it works. Short of that you can look at the manual that came with the truck. The manual will tell you everything you want to know about the truck and its components.
  6. IROCUBabe
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    I have consulted the manual to no avail it was my first point of reference before I came to ask you guys. I can get it to stop shutting off by hitting the gas but I am more worried about the times I wont be here, my pet will be alone and the truck off its 100 degrees today, the truck shut itself off when I went into a truck stop to grab a snack and when I came out it was 116 in the truck.
    I am at the terminal now telling them to make it stop or get me a new truck >.>
  7. IROCUBabe
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    Well after I hit the clutch instead it quit doing it yay.
  8. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    THAT IS CHEATING!:yes2557:;)
    Glad you got the problem worked out. Hot trucks and pets are just not compatible!
  9. smadronia
    smadronia Heavy Load Member
    938
    278
    May 26, 2007
    Oregon
    How about looking for a fuse diagram and pulling the auto shut off fuse?
    I have no idea where it would be on a Pete, but I know there should be something like that.
  10. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    I would venture to guess your rig is newer than my 379 but this may work. My engine shuts down after 8 minutes. I tried to get my shop to either over-ride it/disable it/ or tell me how to do it myself. They wouldn't do it but at the time, I strictly ran in So-Cal and used it for tugging a low-side. CA kinda frowns on those who bypass or manipulate the ecm settings.
    Anyways I'm rambling, I found out by accident that if you bump up the idle speed up a tick, it'll run all day and night keeping you warm or cool and burning the fuel.
    I only do that if it's either Palm Springs Hot or cold like where Brickman lives.:biggrin_25523:
    I like it cool but I'm not as tough as Brickman.:biggrin_25523::biggrin_25514:
  11. roadkill4512
    roadkill4512 Medium Load Member
    396
    241
    May 9, 2008
    Lancaster,PA
    Our freightliners are the same way. However setting the cruise control keeps it idling for as long as you want. I don't understand why your CC wouldn't work.
