Air bags deflate overnight
Discussion in 'Kenworth Forum' started by TankerYanker79, Apr 16, 2018.
  1. TankerYanker79
    TankerYanker79 Bobtail Member
    Bristol, Vermont
    My 2016 W900 just started leaking down overnight on both the suspension bags and cab bags. Talked to couple other guys having similar issues. No audible leaks or breaks. Will build and hold air and a load fine. Was thinking it could be Pressure protection valve off the tank. Any suggestions? Thanks
  3. DUNE-T
    DUNE-T Road Train Member
    6,906
    16,711
    May 10, 2015
    Detroit, MI
    On my truck it was dash valve. Could not find the problem for months
    TankerYanker79 Thanks this.
  4. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Soapy water in a spray bottle and go hard. Only way to actually find it
    TGUNKEL and spsauerland Thank this.
  5. Red Rocket 1964
    Red Rocket 1964 Light Load Member
    115
    44
    Jan 31, 2013
    air ride cab bags is where i would start
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Also ck air valve on ride hi.
  7. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Check the fittings. A lot of those use the push in fittings, which aren't the best for longevity.
