air brake questions
Discussion in 'Questions From New Drivers' started by kloy, Aug 6, 2012.
  1. meistreguy
    meistreguy Bobtail Member
    29
    6
    Aug 6, 2012
    No, when you push on the brake pedal (treadle valve), it will force air into the system so the shoes will contact the drums, just like spring brakes but it is a separate system. The red air line puts air into the system so the spring brakes release and when you step on the brakes, the blue line carries the air to the brakes. I hope I explained that correctly.
  3. drdave
    drdave Light Load Member
    105
    52
    Jul 23, 2012
    Seattle, WA
    Something was wrong with that. Both lines hold air...... That is why they are called air lines. Smile
  4. Tenspeed70
    Tenspeed70 Light Load Member
    69
    39
    Mar 20, 2011
    Chittenden, VT
    The red line supplies constant air to compress the spring brakes. The blue line supplies air when the brakes are applied.
  5. docstat
    docstat Bobtail Member
    thanks for the information. Not sure how someone can pass the airbrake test without understanding that it is a dual system: the service brakes, and the parking/emergency brake system. How much weight loss are we talking about with the free movement of the wheels.
