Air building too slow, purge valve question
Discussion in 'Freightliner Forum' started by MercerDriver, Nov 12, 2014.
  1. MercerDriver
    MercerDriver Light Load Member
    69
    7
    Sep 3, 2010
    Atlanta, GA
    Long story, short.
    Had the truck parked for about 10 weeks.
    Started it up, air building a lot slower than it used to.
    Also, all of a sudden, at 130 psi, the purge valve kocks in and stays open till gauges show approximately 110 psi. Then the cycle repeats.
    What is causing the purge valve to stay open and dump air out ???
    Detroit 60, 12.7. Governer mounted on air dryer unit.
  3. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    when purge valves and stays open have ya tapped on it to get it to close. sounds a malfunctioning purge valve, it can possibly replaced separately without the entire dryer being replaced. does it have a cartridge filter, if so that baby needs to be replaced on a regular basis
  4. 062
    062 Road Train Member
    6,144
    33,187
    Oct 20, 2013
    What make of dryer?
  5. MercerDriver
    69
    7
    Sep 3, 2010
    Atlanta, GA
    It's a Bendix with the cartridge on top and governer that bolts right to it.
  6. 062
    6,144
    33,187
    Oct 20, 2013
    Probably purge valve,I have a wabco that was doing the same thing. But mine was caused by road debris,hit a piece of metal dinged purge valve,cracked regen housing. If it's constantly cycling you can stop at hardware store and get some pipe fittings to bypass it until you can fix it
  7. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    Did you fix it ?
    Have exactly the same problem but on Volvo with Bendix AD-9 air dryer..
    it purges at 125 psi , purge valve slowly leaking to 120 psi ( can see it on gauges ) and cycles again :(
    Do you know what could it be ?
    Thank you!
  8. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Are you guys in cold climates? I had the same happen to me with same dryer. Took of the big line off the compressor and put some ethynol in there and whammy! Purges like a somabich.
  9. dustinbrock
    1,308
    901
    Apr 19, 2012
    Sorry. Methynol not ethynol
