Air Compressor cycles between 110 and 120 psi while cold
Discussion in 'Volvo Forum' started by dorlia2, Nov 21, 2016.
  1. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Strange problem with compressor since it got cold in the midwest. When starting a cold engine compressor cycles between 110 and 120 psi. Governor is new as is the compressor and dryer. This happens only until engine warms up and gets back to normal 90- 120 psi. Any test I can perform before taking compressor head apart. 2006 ved 12
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    I wouldn't worry about it. Sounds like the governor is cold and as the temp rises the set screw is expanding with the heat. If after the engine is up to temp and the pressure stabilizes you should be fine.
  4. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    I dont believe its normal, just because it has not happened before. Also 10 psi drop in 20 seconds is definitely not normal, as well is a DOT violation. Thank you for your answer, but a new governor doesn't fix the problem. Sticking valves in the compressor head is my best guess. I hope I didnt spend $1800 for a garbage compressor sold by dealerships. Yes, I know its under warranty but its a hassle to deal with, and involves spending time and money.
    KB3MMX Thanks this.
  5. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    it's fine what are worrying about nothings is wrong you don't drive while the engine is cold anyway you let it idle and warm up before you drive problem solved higher pressure is better anyway.
  6. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Noticed that problem occurs also when AC is on and truck is stationary. Any ideas if that has to do with fan solenoid.
    KB3MMX Thanks this.
  7. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    I Would try first to replace the govener... 20$
  8. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Thanks but already did
  9. dorlia2
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
    Still having the same problem. Any ideas would be appreciated
  10. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Try replacing dessicant ... Air dryer cartridge. It's cheap.... Should be once a year anyway... Especially if you have a DPF truck.
    If no luck, replace the governor ... Also very cheap.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    I would not worry about it at all.
    As long the air pressure stays within limits it's all good. You are watching science in action as the air heats up, moisture removed etc.
    Don't go pulling stuff. That's expensive. Not without a hard failure somewhere in your system.
    dynamite Thanks this.
